ISW on 4 series and above
  • rrrohan
    • Sep 2011
    • 1977
    Trying to get ISW to work again.
    Havent used it since C360 days.
    Back then it was just a .tar file that you needed to point to.
    Now since all the files are extracted onto a USB, what file do I point to?
  • B0265
    • Jan 2007
    • 718
    Re: ISW on 4 series and above
    I also havn't used the procedure for many years, but it's described in the service manual how to create the .tar file
    • antone
      • Oct 2014
      • 344
      Still tar file
      Sent from my SM-N950U using Tapatalk
      • Synthohol
        Certified Konica Expert
        • 5885
        no ISW anymore for a while.
        just extract the files on to the root of the flash drive and boot with it plugged into the covered service port in the back.
        • rrrohan
          • Sep 2011
          • 1977
          Had a c458 that didn't want to take firmware and it reminded me of how in the past I would use ISW instead.
          Thanks for info. I'll try get it to work again
          • darry1322
            • Oct 2010
            • 817
            Press and hold the stop button while you power on the machine to enter firmware screen.
            Copy the FW0002 folder to the root of a clean drive and insert the drive into the side usb port ( the one used to print from or scan to usb).
            • Synthohol
              • 5885
              thats the 8 series not the 4 series (just for clarification) 8 series the USB goes in the control panel USB and the 4 series its a USB service port on the side of the MFP board hidden by a plate and screw.
              • darry1322
                • Oct 2010
                • 817
                Yep. He last posted he was trying to do the firmware on a C458 so I wanted to make sure he was using the correct procedure for the C458.
                • tsbservice
                  Field tech
                  • 8043
                  Regarding C458 that didn't want to take firmware-check machine for incorrect placement of front USB cable.
                  • Woxner
                    • Jul 2011
                    • 852
                    on the 4 series all you need to do is copy all the files in the folder. the folder ends in (00)
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      What genius at Konica decided to "de-simplify" their firmware procedure? Why not bring back the CF card
                      • rrrohan
                        • Sep 2011
                        • 1977
                        I tried plugging direct to the front USB port on MFP too.
                        • Synthohol
                          • 5885
                          what kind/size flash drive?
                          4G or less i hope.
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Not sure where KM think we are shopping if they expect us to find 4GB or less.
                            But I got a 8GB old faithful.
                            But in this case I forgot to bring it and the crappy grocery store selection it just didn't like.
                            It was more the fact I want to start using the tools KM provide like remote deployment and ISW
