C3851 fs
  • CloneTJ
    • Mar 2014
    • 8
    C3851 fs
    Does anyone know if there is a way to run the c3851fs without the internal finisher?
  • 3ktlc
    • Feb 2018
    • 180
    Re: C3851 fs
    Try service mode. System 1. Unit isolation. There must be another way though. In Europe, the finisher is an option.
    • rrrohan
      • Sep 2011
      • 1977
      Re: C3851 fs
      You just physically remove it.
      Is it causing problems?
        • 14691
        Re: C3851 fs
        What have you got against this cheesy, incredibly flimsy marvel of modern engineering?
        • Albonline
          • Sep 2008
          • 1148
          Re: C3851 fs
          just an fyi the 3850fs finisher will plug in and go. there are bulletins about these units, in a nutshell remove, disassemble,CLEAN,and lube the rails and things that move on them with drysurf. i have had good luck fixing these by doing this. i in the past have used plusguard also with good results.
          • Woxner
            • Jul 2011
            • 848
            Re: C3851 fs
            you can just disable it and will just pull the copies out yourself. same as last post said isolation.
