Bizhub C224e Unknown Issue
    • 23008
    #16
    Re: Bizhub C224e Unknown Issue
    I've seen a black screen as a result of bad page memory. Once the page memory was changed I got other errors that led me to the PRCB (when I could read on the screen). =^..^=
    • rrrohan
      • Sep 2011
      • 1977
      #17
      Originally posted by copyman
      Try turning on machine with the USB service port door open and no flash drive inserted. This metal cover is secured with one screw. This metal little cover blocks a sensor when closed. There is a bulletin about leaving this open for machine that won't boot up. It's just for troubleshooting purposes but will allow you to enter enter service modes etc. to format HDD, SSD, etc. I had one C224 I had to leave open permanently for customer to use machine.
      Agree with other poster always turn off sleep mode. You have to go into service mode first and "permit" sleep mode change. Then turn off in admin mode.
      i didnt know this trick. handy to know. i only knew about entering it via trouble reset
      last 224 i had stuck on 2 fins ended up being SSD.
      But my symptoms were it got 2 shark fins and would reboot in a constant never ending loop
      I couldnt load firmware or anything
      But it did sound like everything was starting up
      • Oystercopy
        • Oct 2009
        • 623
        #18
        I don't know about the rest of you guys, but the original poster does not sound like a technician at all (I believe he even admits that in the beginning) but I've read through EVERY message in this thread, and the guy is in WAY over his head... he's doing things to the machine that even I WOULDN'T DO, without thorough research and consultation with other experienced techs, and I've been doing this over 40 years at this point. The C-224/284/364 series went through a SLEW of issues with HDD, boards, etc and a novice has no business going into this much detail on a machine he knows nothing about.
        Just my 2 cents, but I would stop helping him for fear of what liability there may be on your (our) end.
        OC
        • rrrohan
          • Sep 2011
          • 1977
          #19
          Originally posted by Oystercopy
          I don't know about the rest of you guys, but the original poster does not sound like a technician at all (I believe he even admits that in the beginning) but I've read through EVERY message in this thread, and the guy is WAY over his head... he's doing things to the machine that even I WOULDN'T DO, without thorough research and consultation with other experienced techs, and I've been doing this over 40 years at this point. The C-224/284/364 series went through a SLEW of issues with HDD, boards, etc and a novice has no business going into this much detail on a machine he knows nothing about.
          OC
          well if it is the SSD and he isnt a tech this will be the brick wall he hits when trying to order one
          • Ari007
            • Apr 2019
            • 49
            #20
            OC
            Thank you for your suggestion. **No one will face anything.. this is a public forum, all you can do is help other techs if the issue is known to you. The tech will proceed with his own risk. Because disaster machine's issues gets posted here.
            Things are a little different here. KM follows a shady business policy and there are lack of techs. If I call the dealer to send a tech, they sends people without sound knowledge of these machines. They just come and starts to call another people over the phone and proceeds with just swapping things and checking if the machine is up or not.
            I am an electronics & communication engineer and I'm well aware of the risks. I might be a newbie compared to the techs present in this forum but I do studied this particular machine and I do understand the working principle of it.
            I had no other option than proceeding on my own because I have depended on the techs of the dealer and they left my machine sitting in my home at least four months.
            Now, I do have connection with other dealers techs and I can order parts as per my requirements after consulting with them.
            And Coming to this machine if anyone faces two shark fins just update the firmware to M0 right away.
            Olivetti D-Color MF222Plus-282Plus-362Plus firmware is same as Konica's bizhub C224e-C284e-C364e series. (I have tested it with C224e)
            Now my request to all of you, if anyone can upload the technical bulletins from KM tech regarding this ssd issue it'll be a great help for me.
            Thank you.
            • Ari007
              • Apr 2019
              • 49
              #21
              Originally posted by gere1
              have you tried to change the ssd
              I had something similar probe all the fimware I had
              It worked a few days and another see black screen
              when changing ssd the problem was not repeated
              I'm discussing it with the dealer's head tech. He asked me to visit his office, will have an F2F convo then proceed.
              • Ari007
                • Apr 2019
                • 49
                #22
                Did you try what I posted earlier?
                Yes, I tried. But no luck.
                If I discharge the DC power supply and turn the power on after approx 3hrs, the machine boots up and Shows two shark fins.
                One good thing is it still accepts the firmware and installs it successfully, So the MFPB is not dead and as this machine faced display freezing changing the MFPB will not help. I'm looking forward to replace the SSD, told the dealer tech, he agreed and asked for a F2F convo as mentioned in the earlier post.
                • Ari007
                  • Apr 2019
                  • 49
                  #23
                  Faced this issue in Aug,18. Called the tech and he came & called a guy & followed that guy's instructions, did the unplug/plug DC power supply connectors and waited for a while...powered on & machine booted up..
                  If he had updated the K6 firmware of the machine to K9 and then M0 back then, my machine would have been fine today.
                  P.S: This machine never showed a problem regarding print quality. Toner changed with original konica toner just few days ago for the first time.
                  • Ari007
                    • Apr 2019
                    • 49
                    #24
                    [Update]
                    After keeping the machine turned off for 10hrs, I turned the machine on. Booted up fine but took a longer time. CD390 error showed and recover data option is there but suddenly a internal error auto cancel screen came and when I was entering password to log in into service menu machine went off for restarting because of that error but not turned on again. It stayed off with power and notification light glowing. When I turned the main sw off/on, it didn't booted.
                    If I can click the recover data button then the machine will become fine again like previous time, work for some days and will show this problem again.
                    Meeting with the dealer's tech is rescheduled to Tuesday. I'll update once it happens.
                    I think if my machine's weird issue gets solved it'll help many other people.
                    Ordering Brand New MFPB is the worst option because they'll charge almost $1000 for that and you'll get an used working machine for around $1800 .
                    • Ari007
                      • Apr 2019
                      • 49
                      #25
                      Re: Bizhub C224e Unknown Issue (including dual sharkfin) //Partially Solved
                      [Update]
                      Machine booted up successfully.
                      Turned the machine on at 9am and turned off at 3pm.
                      Total 250+ duplex copies printed from pdf. (No errors/jams)
                      After turning the main sw off tried to turn it on again but it didn't started. Have to wait for another 4hrs (approx) to turn it back on again.
                      Issue is partially solved without replacing anything.
                      Will continue trying to fix it completely. Updates will continue.
                      Any suggestions? anyone??
                      • allan
                        RTFM!!
                        • 5462
                        #26
                        Sounds funky for a solid-state device.
                        Did not read the entire thread due to the facepalm factor.
                        Have you changed out the PSU?
                        Whatever
                        • Ari007
                          • Apr 2019
                          • 49
                          #27
                          Checked the PSU multiple times. Output is as per specs.
                          I have no other options left, that's why decided to go on my own.
                          Today that tech calls me and says "Sir we faced another case like your machine, please tell me how did you fixed this issue??"
                          I was like wtf!!... told "CMOS battery reset".. which went way over his head and he asked me to send a photo of it from my machine's motherboard!!!!
                          Now you can imagine my condition, and I have 0% trust on these guys.
                          Any comments on this
                          • allan
                            RTFM!!
                            • 5462
                            #28
                            Its not a conventional computer stuff gets written to EEPROM and NVRAM.
                            Firmware, bit switches, user data, engine data and security stuff like license management.
                            The only thing apart from NVRAM would be a RTC that would need a battery.
                            SSD does not require a battery but is also NVRAM.
                            Also curious to what battery you are referring to and would also like to see picture...
                            Konica Minolta goes to great lenght on the newer machines to make sure LK's does not get reproduced by cracking.
                            There is something that is called original factory data that can get lost or security data that gets mismatched.
                            They don't share the secrets on how this works in detail.
                            The reset tool is too small in file size to be replacement data and is probably more like an instruction to clear and reset security related info.
                            The machines does a NVRAM backup every hour or so and if that does not go to plan you will get an error code in the range of C-D3XX.
                            C-D301 and C-D370 comes to mind.
                            Next time you get the machine running go and check the SC history for those codes.
                            Also try a manual NVRAM backup under enhanced security settings, my guess is the machine will lock up on you right then and there.
                            Let us know if that happens.
                            You could have fixed this by replacing SSD only. There was a time where KM release the update on the SSD to avoid a condition where the SSD would become unrecoverable.
                            They would then replace those SSD for the dealer on request but there was a time window where they asked that all machines be checked and upgraded.
                            Very possible that now you would need both factory issued SSD and MFPB and its said that that can't be done(so they say)... or a complete donor machine.
                            Also you can propagate the problem from boards you have on hand to the replacements that could cause much frustration.
                            There is not a lot of info on this topic because it should never happen.
                            Or its just a hardware issue like bad onboard RAM.
                            In short you are in over your head like mentioned...
                            Whatever
                            • Ari007
                              • Apr 2019
                              • 49
                              #29
                              Yes.. Because I do know that if I don't get the factory issued SSD then donor machine is my only option, thats why I'm trying every possible combination.
                              And one more thing, I've faced that security warning/error two months back and successfully bypassed/fixed it.
                              Method:
                              When you get a security error, you can't login to service mode directly (Menu> Counter> Stop - 00 - Stop - 01).
                              To solve this: (Disconnect one terminal of CMOS Battery and wait for 5mins then Reconnect by applying a electrical tape, BAT1 in Schematic of Service Manual.)
                              1> Flash the tar. (In my case A145FW.TAR)
                              2> Boot to Trouble Reset.
                              3> Enter Service mode & Input Serial Number.
                              4> Your machine is fine.
                              Red circled in image attached. IMG20190211230545 — imgbb.com
                              • allan
                                RTFM!!
                                • 5462
                                #30
                                Hope you get your machine sorted.
                                Keep us informed on your progress.
                                Whatever
