KM c6500 fiery ic-408 software problem
  • rafal.kuliczkowski
    • Apr 2019
    • 5
    [Dead] KM c6500 fiery ic-408 software problem
    Halo,
    I'm writting to you for help. after no electricity problem in my company fiery gives me FF error. I made everything like service manual tolds me to. My friend gives me iso image of software, and when i connect computer with (cross cable) win xp sp2, then sp3, then win xp from vbox and try to start installation with fieryinstaller.exe nothing happend. When i try to start it from command prompt it gives me "program too big to fit in memory". Can anyone help me with that softwere ? I'm starting to think that there is something wrong with that iso image.
    (before i wrote this i clean the cmos, and made everything what i find on this forum)
    Thank you very much for your advices.
    • Apr 2019
    • 5
    Re: KM c6500 fiery ic-408 software problem
    there is the photo how iso image looks like
    • Synthohol
      Certified Konica Expert
      • 5905
      did you flip the switches?
      did you plug the ethernet into the copier port on the fiery?
        • Apr 2019
        • 5
        yes i turn the service switches to "on" position and connect computer with fiery via crossover cable
        • Synthohol
          • 5905
          to the copier port on the fiery right? not the LAN port.
            • Apr 2019
            • 5
            yes, I unplugged all other cables and connect only computer-fiery via ethernet slot
            • Copia
              • Apr 2019
              • 10
              What I recall on those controller was bad with Ethernet Installation Method. I suggest use the USB installation instead.
              Installation to the USB takes about 15-20min then it will take another 45 when you install the USB into the fiery.
              There is an EFI Tool for installing the ISO into the USB.
              • purple
                • Mar 2023
                • 12
                Hello, where can I download software from?
