C360 freezes up when attached to network cable.
  • JimmyT
    • Apr 2019
    • 7
    [Misc] C360 freezes up when attached to network cable.
    Hello everyone,
    So few months ago I have this C360 where it freezes up after I plugged in network cable. It usually takes around 5 - 10minutes.
    It basically display main copy screen, and no buttons or touch screen is functioning.
    also when the network cable is disconnected, it functions with no problem at all.
    Originally I thought there is something wrong with the access point connected to the machine, so I exchanged that. It worked, until last Friday.
    Any idea? The machine had been running for 2 years with no issue until now. If anything, there is a change in machine physical location when the problem first pops up.
    • 23010
    Re: C360 freezes up when attached to network cable.
    Very likely, some kind of non-print data is hitting your printers IP. The hard part is that is nearly impossible to find the source ... literally anywhere on the network. The simplest solution is to change the printers IP address, then one at a time change the port at each print driver. The data that is offending your C360 will still be out there, but it won't matter, since it's not coming to the printer. =^..^=
    • allan
      RTFM!!
      • 5462
      Also try changing network speed setting from auto to 100mbs.
      Connect a laptop to it and check.
      Have had switches that would cause KM machines to lock up.
      Whatever
      • copier tech
        • 8236
        Is the copier on DHCP or static?
        • BaconSteve
          • Apr 2019
          • 140
          • allan
            RTFM!!
            • 5462
            Mmm that explains some of my previous problems i had.
            So would it not help to simply cut the fly lead wires that goes to pin 4 and 5 on the RJ-45 connector?
            Whatever
            • BaconSteve
              • Apr 2019
              • 140
              • Terna247
                • Jan 2019
                • 64
                Seen that before, replaced the modules(memory) and was good. Try that.
                • JimmyT
                  • Apr 2019
                  • 7
                  Hi everyone,
                  Apologies for the late (rather very late) reply. Turns out after I have replaced with a Wifi access point (which acts as wireless client for the machine) and a network cable. The problem seem to have go away by itself, as so far the machine has yet to freeze up any more
                  Edit: I've also replaced the power cord as well though I'm not sure if it's related.
