Bizhub C227 goes into deep sleep. User has to turn the machine off and then on.
  • nelo
    • Apr 2019
    • 32
    Hello There
    I have a bizhub C227 in my workshop and it cant come back on when it's in deep sleep. If a print is made the machine still stays in deep sleep / or high power save mode. I'll have to press the sub power button for some time to bring the machine back on. Normally when I touch any key it should come on from sleep.
    With this issue on hand I remember a bizhub C364e that has the same issue and was rectified by installaing a specific firmware fix for deep sleep / power save issue.
    For the mean time I have switched off the power save / sleep settings and am searching for firmwares and documents to help fix the actual fault but have only viewed for power save / sleep on and off time settings in knova.
    I haven't tried updating to any latest firmware yet .
    If anyone who may have come across the same issue kindly assist me here.
    Regards
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: Bizhub C227 goes into deep sleep. User has to turn the machine off and then on.
    in service mode select "permit" for sleep mode then disable sleep in admin mode.
    • Bix
      • Apr 2018
      • 1421
      Hi, here are some best practices:
      Service> System 1> Sleep / on / off choice setting> Permit.
      Admin Menu:
      1. System Settings> Power Setup / Power Saver:
      - Pause mode: no
      - Power button settings: energy saving.
      - Energy saving mode: energy saving.
      - Enable energy saving: normal.
      - Power consumption in pause mode: Active
      2. Weekly timer settings set to ON, select pause and return to off.
      Update the FW to the latest version 4.2
      • kingarthur
        • 1337
        on all m/c's I install, I set the power save as follows
        Enter Power Save Mode change it to "NORMAL"
        Power Consumption in Sleep Mode change it to "DISABLED"
        There was a bulletin for the C224, which advised to do this for the same problem.
        • nelo
          • Apr 2019
          • 32
          Admin Menu:
          - Pause mode: no
          I will try this and get back to this post on the result.
          Big thanks!
          • nelo
            • Apr 2019
            • 32
            Thank you for your reply. Will try do this and get back to this post with the results.
            Big thanks!
