Bizhub C6500 Error code C-4520
  • tulintron
    • Jul 2014
    • 668
    #16
    Re: Bizhub C6500 Error code C-4520
    Originally posted by Desert Rat
    I think at this point, I would dig into the drum drive. I've cleaned these gears to keep them running smooth. May be they are worn?
    How many total prints on these machines?
    Have you tried the manual registration program? At least have a look at the prints from that program to see if thing are really off.
    Just a thought
    DR
    Total counter - 1,500K
    Kit 200K - 60k (43%)
    Drum's - 60K (45%)
    Developer's -60K (45%)
    Charge Coronas - 60K (72%)
    Ran the Color Registration Manual and finished OK.
    Although, I believe this setting is for copying only.
    In this case, the client is only printing. Do not copy.
    On the C6500P, this setting is not available.
    • Desert Rat
      • May 2008
      • 1089
      #17
      I have had to use the "Recall standard Data" from time to time also.
      Please keep us informed. I still have a couple of these out there also.
      Dr
      • tulintron
        • Jul 2014
        • 668
        #18
        Dr
        Okay. Notice when you solve.
        In fact, the plates were all changed.
        OACB-IPB-PRCB-DCPS1-DCPS2- IC Unit- Firmware.
        I also mounted these same parts on another C6500, to discard possibilities of some wire or connector.
        It's going to be difficult, but I'm going to try to convince the customer to change the 100k, 200k, drums and developers kit.
        Any news, notice here.
        Thank you all.
        • tulintron
          • Jul 2014
          • 668
          #19
          Good morning everyone. I will close this request for help. The customer decided to change equipment after requesting the PM kits.
          Thank you all for your help. This forum is awesome!
            • 23010
            #20
            Hopefully you didn't get stuck with an armload of obsolete parts. But its a good thing to get that old beast out of the field. =^..^=
            • tulintron
              • Jul 2014
              • 668
              #21
              It will turn into a beautiful maintenance table. Hehehe.
              Obrigaod for helping!
