Black line C258
  • Bix
    • Apr 2018
    • 1421
    Black line C258
    hi, today I found a strange call.
    the customer signals me a black line on his bizhub c258. The printer has only 60k and this seems a little strange to me.
    The sign is perfectly linear and always in the same point. Sometimes it is more evident sometimes a little lighter. I found a toner line in the metal part of the belt roller. I cleaned without result.
    It happens both in color and black and white prints. The surface of the black drum does not seem to have signs, as soon as I extracted I found a white dot that I removed but did not solve the problem.
    The calibration is unfortunately not worked.
    Some idea?
  • tsbservice
    Field tech
    • 8007
    Re: Black line C258
    I would crash stop machine during copy/print to see where is the black line. It looks like K drum has small scratch, or its cleaning blade fails. Check for small piles of toner/developer along dev unit, TBU etc. Good luck.
    • tech51
      • 846
      • copyman
        Owner / Technician
        • Sep 2005
        • 4679
        Re: Black line C258
        If you run single colors in test mode and no lines on the 3 colors then only thing it could be is K drum. It use to be easy to confirm this by swapping K drum & chip with a color drum, but now the chips are riveted in.
        Think you are going to find it is the K drum.
          • 14701
          Re: Black line C258
          If the black drum has reached it yield there is a 99.99% chance the drum is at fault.
          • tsbservice
            Field tech
            • 8007
            Re: Black line C258
            At 60k I highly doubt that K drum is due(by any count), but yet it seems most likely at fault.
            • tech51
              • 846
              Re: Black line C258
              • darry1322
                • Oct 2010
                • 817
                Re: Black line C258
                I replaced a C308 black drum last week for a similar problem. Drum surface looked beautiful, but the new drum cleared it right up.
                • tsbservice
                  Field tech
                  • 8007
                  Re: Black line C258
                  Yeah, long time ago I heard about drums rotations time, cars oil change based not on mileage but on actual usage/idling/driving conditions etc. Still can't believe that in this case K drum is due by any count.
                  • tech51
                    • 846
                    Re: Black line C258
                    • allan
                      RTFM!!
                      • 5462
                      Re: Black line C258
                      Something on the charge roller?
                      If that is the case i will have a wack at cleaning it.
                      Whatever
                      • darry1322
                        • Oct 2010
                        • 817
                        Re: Black line C258
                        Charge roller was clean and pristine as well.
                        • tsbservice
                          Field tech
                          • 8007
                          Re: Black line C258
                          I can't pretend to be KM expert by any means, and seems from what I have read that you knowing Bizhubs to the bones. Luckily, I had no premature wear on 8 series drums but that issue is known to me and sharing your experience on new long life drums will be nice.
                          • allan
                            RTFM!!
                            • 5462
                            Re: Black line C258
                            Mag roller?
                            Bix it looks like there could be a repeating pattern were the line goes from fat to thin on that sample can you get a measurement of that?
                            Whatever
                            • Bix
                              • Apr 2018
                              • 1421
                              Re: Black line C258
                              Heck, I've forgotten patterns. Indeed they could tighten for the solution of the problem.
                              I will try with the replacement of the K drum. I have many series 8 and the drum has always almost respected his life. This could be one of the first cases. In any case, the printer at 2 years then the drum could be aged (?) I keep you updated
                              Switch from thin to thick and vice versa between 5-10 pages
