White Toner Filters in Konica Minolta bizhub 454e
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] White Toner Filters in Konica Minolta bizhub 454e
    We have a Konica Minolta bizhub 454e out in the field. In regards to the white toner filter, we have noticed that in 2 months it can turn a pristine white toner filter all black with toner. We have an internal debate here on whether this is normal or not. Could you wonderful people please comment on your experiences with how long it should take to fill a toner filter and/or what would be considered an abnormal amount of toner in a set amount of time for a bizhub 454e toner filter? Thank you in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: White Toner Filters in Konica Minolta bizhub 454e
    Well, that's a loaded question. Kind of like asking how many pages can I get out of a toner bottle. Same thing applies here. If the prints/copies are high coverage per page, then yes it would get the toner filter filled up pretty fast. If the bulk of prints/copies are 6% B/W ratio, then I would think the filter wouldn't get that dirty. In the field, I never check that filter until I change it at PM time. It's dirty then but I'd expect that.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • Synthohol
      Certified Konica Expert
      • 5892
      depends on the machines environment and fill rate.
      if the coverage is high then the normal toner misting will likely be heavier.
      and/or if the consumables are old it will use more toner and shmutz up the filter faster.
      make sure all the vents and fans are cleaned and able to circulate at 100%
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        Normal. Never met one that wasn't saturated with toner except brand new out of package.
        • allan
          RTFM!!
          • 5462
          Well stated.
          Just vacuum it and replace when you get a transfer belt kit.
          Means its working well and the toner in the filter does not end up in the engine.
          Whatever
          • rrrohan
            • Sep 2011
            • 1977
            it must depend on the printing because depending on the customer the main colour in the filter changes
            • tech51
              • 846
