C224 problem after replacing drum
  • darkocg88
    • Jan 2018
    • 63
    This is how print looks after replacing the K drum.
    Any idea what's the reason for these stripes?
    Sent from my Moto E (4) Plus using Tapatalk
  • copyman
    Owner / Technician
    • Sep 2005
    • 4707
    Re: C224 problem after replacing drum
    Where the same lines there before replacing drum?
    Did you use a new "Genuine" OEM drum? Still looks like a bad K drum
    Clean laser print heads with wand on front door? And coronas with white rods you pull out and in on each drum unit?
    • darkocg88
      • Jan 2018
      • 63
      Different lines before replacement.
      Genuine drum was put in.
      • mo0651
        • 1054
        Really?? Lines go clear to the edge. Transfer belt, fuser. Stop test.
        • allan
          RTFM!!
          • 5462
          Swap it out with the yellow drum just change the chips over. If the corner of the chip breaks out its still ok just glue it back.
          More likely to be a dev/toner buildup on the dev tank.
          Had faulty new drums before but very rare.
          Remove and inspect the dev tank.
          Whatever
          • darkocg88
            • Jan 2018
            • 63
            Thanks, that was my doubt as well. Dev.
            • allan
              RTFM!!
              • 5462
              If its over or close to 300K then its done its work replace it.
              Its quick to pull out the tank and check it, have you done that?
              Whatever
              • allan
                RTFM!!
                • 5462
                So its not done 200K yet?
                Whatever
                • tsbservice
                  Field tech
                  • 8018
                  Well, atleast if TC it's not over million
                  Might be, but more likely it's under 200k little early for developer.
                  Agree, do some crash stop testing will help to determine the problem between TBU and IU(drum+dev).
                  • copier tech
                    • 8149
                    If you want an accurate answer post 4x gradation prints this will give us more info to go on.
                    If the laser (print head) was dirty you would have white lines/deletions.
                    Developer unit will not produce thin black lines as per your print sample.
                    Silly question (seen it many times) are you sure you fitted a NEW black image unit?
                    If you have 100 % fitted a new K IU the issue is with the transfer unit.
