C3351
  • CloneTJ
    • Mar 2014
    • 8
    [CQ] C3351
    Hi All
    I have a c3351 that has some minor skew. I have tried adjusting the registration values and still hasn't helped.
    Any Ideas?
    Re: C3351
    Originally posted by CloneTJ
    Hi All
    Any Ideas?
    print and copy?
    are tray guides tight?
    anything in aper path blocking travel?
    life on parts?
    need more info
    Phil B. "The Dentist"
    • tsbservice
      Field tech
      • 8019
      Re: C3351
      Skew when copying or printing, or both?
      Could be as simple as ADF needs alignment/adjustments.
      What about using bypass tray, does it skew?
      • copier tech
        • 8164
        Re: C3351
        More info needed.
        Are the prints ok?
        Is the skew only from DF?
        Is the skew from the glass?
        โ€‹
