Firmware
  • antone
    • Oct 2014
    • 344
    Firmware
    How do you get the ISW ...need help in up dating firmware .Went into SM and hard to understand!
    Sent from my SM-N950U using Tapatalk
  • Woxner
    • Jul 2011
    • 851
    Re: Firmware
    what machine
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Re: Firmware
      Why can't you do it the more conventional and easier way with a thumb drive or CF card depending model?
      You can ask and someone here will provide you with F/W if you need it.
      • rrrohan
        • Sep 2011
        • 1977
        Re: Firmware
        i havent done it via ISW since they stopped giving you firmware as a single file.
        never been able to get it to work since 4 series and to be honest I dont see the use in it anyway. much faster to do it via USB
        • antone
          • Oct 2014
          • 344
          Re: Firmware
          Biz 601 firmware...how is it done with thump drive!
          • darry1322
            • Oct 2010
            • 817
            Re: Firmware
            If I remember correctly the Bizhub 601 uses a CF card that resides in the machine. Check your service manual to make sure.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4723
              Re: Firmware
              You update the Biz 601 firmware with a thumb / jump drive using the USB port on front of machine. I remember having to install the F/W in steps, will not install correctly if you try to jump right to latest F/W
              This is out of the service manual:
              • nassor
                • Sep 2017
                • 30
                Re: Firmware
                It use cf card
                • tsbservice
                  Field tech
                  • 8020
                  Re: Firmware
                  Originally posted by nassor
                  It use cf card
                  Nope. Check out procedure in SM described above from copyman.
                  • emujo2
                    • Mar 2017
                    • 1579
                    Re: Firmware
                    You use the CF card to re install base firmware, but thumb (or thump lol) drive for subsequent updates.
