C454 - Paper comes out curly (approximately from the half)
Re: C454 - Paper comes out curly (approximately from the half)
Looks like either high temperature in the fusing unit or a motor is going to slow.
EDIT: bad temperature on the fusing unit could be because of hot enviroment. try to move the machine to a cold room, for example a kitchen or bathroom and test it there.Comment
I am in a workshop. Always at room temperature in the shop.Comment
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
I replaced the whole unit. print out still curls. There is no paper jam. While it is printing I did open to see where it starts, it happens after it passes the fusing unit.
[ATTACH=CONFIG]54333[/ATTACH][ATTACH=CONFIG]54334[/ATTACH]
this is what i get.
I checked the gears and they all are fine. No wear on them.WhateverComment
I have replace the fusing drive.
Changed the fusing unit too.
Replaced the exit and reverse unit.
Transfer roller.
Cleaned the rollers changed the paper.
Tried to change the speed and the temperature.
And the ripples start after the fusing unit. tested a newer fusing unit.
Still does that ripple/wavy printout.
Just wondering if there is a problem with the frame?
Can this caused by bending of the frame?Comment
It happened all of a sudden. I am still in training.
Transfer roller.
Can this caused by bending of the frame?A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Hello,
I am so desparate!
A bizhub C454e (total Count around 1,5 Million) shows the following problem: The paper shows about halfway a wave-line shape.
I habe already changed the following parts:
1. Paper Exit unit
2. Fixing unit
3. Reversal unit
4. Fixing drive assy
The registration roller drive smooth (all 4 bearings are oiled)
but unfortunatelly the Problem still exists!
any other ideas?Comment
When you say "new fuser", is it really a new fuser or repaired or rebuilt? Otherwise yes, try known good paper.
Do you have a photo of the symptom? Is there a finisher installed? =^..^=If you'd like a serious answer to your request:
I had very similar issue and the problem was with the reversal unit - it's that thing that guides the paper after it leaves the fusing unit, that can direct the sheet into duplex and so on. If the gears are not proper (for example someone replaced it with unit from slower machine) You might encounter this kind of problem. It will work, it' won't jam (at least not every time), but it will curl paper.
EDIT: and i mean all three, not just those two coupled together.Comment
