olivetti d-color MF304 copies with cyan or magenta vertical lines
  • GIUBOSS
    • 1421
    hi to all , (should be a bizhub c308 ) and the problem only comes in color copy. I think it's a problem with the scanner section I installed the machine today , new , with original toner. executed stabilization and gradation of colors etc. Any ideas before calling for warranty? I add one photo, regards
  • darry1322
    • Oct 2010
    • 817
    Re: olivetti d-color MF304 copies with cyan or magenta vertical lines
    Lines of shame. Run the machine setup from the beginning and they will go away.
      you didn't follow all the steps in the setup procedure...
      start over....
      complete every step -successfully- before moving on....
      DO NOT SKIP ANY STEP IN THE PROCESS.
      I made the same fubar on my first setup!
      • GIUBOSS
        • 1421
        I have probably skipped some steps. I would like to refresh my memory if someone could help me, thanks
        • Synthohol
          Certified Konica Expert
          • 5815
          here ya go.
          • arahael
            • Mar 2013
            • 97
            in service mode press STOP>3
            • GIUBOSS
              • 1421
              Ok.Thanks. But the client called me yesterday for the installation but he didn't know that today another installation technician would come. I did a useless job 🤦*♂️
              • darry1322
                • Oct 2010
                • 817
                It happens. That's why we tease other techs with the "Lines of shame" joke. I've been doing this for almost 30 years and every time I set one up I make that first color copy while holding my breath.
                You learned something new. We've all been there. Next time you see this you'll know exactly what's up.
                • GIUBOSS
                  • 1421
                  well i started at age 19 with the dc mita and other brands, i'll never stop learning.
