Konica Minolta 1052
  • lmblmb
    • Aug 2025
    [Error Code] Konica Minolta 1052
    I am getting a code c-2811 when I try to run the service setup for a new rum and developer. When I try and run the step Charge Potential adjustment in faults out with Error 3 and then throws the code. I have changed the Charge wires, Cleaning blades, TPS sensor and the DPS sensor .Nothing The machine will come on but when you try to print the pages are blank. Ant suggestions?
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Konica Minolta 1052
    blow out your aidc/potential sensors around the drum. probably toner blocking the lens.
    Drum potential sensor
    (DPS) data abnormality.
    While in the drum potential
    correction, no
    convergence is obtained
    even after correction is
    made more than 10 times.
    When this condition is
    detected 5 times in
    succession, the error code
    is displayed.
      • 23009
      Is the drum rotating?
      I had AC power cause this on a 950. =^..^=
