4 Series not copying after resetting
  • Taminol
    • 171
    Hi Guys,
    Not sure what we have done on this C224e.
    Picked it up at end of lease - was working fine, took it back to the shop to clean up and sell secondhand.
    We did a resetting procedure issued by KM
    1)Initialize Address Books, Network Settings, Job History, Copy Program:2) Overwrite all data on the HDD
  • tsbservice
    Field tech
    • 8080
    Re: 4 Series not copying after resetting
    Call service mode and under system 2 check that HDD is installed.
    • copier tech
      • 8236
      Yes this is the cause, after an all clear the HDD will become UNSET, simply choose SET & reboot.
      You will also need to reinstall the animation firmware data.
        • 23010
        Exactly this. It happens during your reset procedure. And you'll have to reload Movie Data and any loadable device drivers required. =^..^=
        • Taminol
          • 171
          Oh wow, all 3 of you guys coming up with the same answer!
          Thanks, I shall set the HDD first thing Monday morning.
          Cheers :-)
          • Taminol
            • 171
            Ok, so I'm in the shop this morning and checked if the HDD was set or not, it was displaying as 'installed'.
            I uninstalled and then reinstalled, but no change. Still doesn't copy, print or scan.
            Have only checked the other machine too, this also displays that the HDD is installed.
            Any other ideas....?
            It's got to be something we did during the reset..
            Cheers
              • 15066
              Cheers
              Do the consumables show as passed yield? This can interrupt copying
              • tsbservice
                Field tech
                • 8080
                Could be. Machines were set to not stop after life end and reset somehow returned settings to STOP?
                Check in Service mode - Enhanced security - Life stop settings.
                • Taminol
                  • 171
                  BINGO!
                  Haha, excellent!
                  Thank you.
                  We have now transformed 2 x coffee tables into 2 x MFD's :-)
                  • tsbservice
                    Field tech
                    • 8080
                    BINGO!
                    Haha, excellent!
                    Thank you.
                    Well done.
                    I got this idea from copier addict, so all credit goes to him.
                      • 15066
                      Well done.
                      I don't do this for the glory, just to help people. Lol
                      • tsbservice
                        Field tech
                        • 8080
                        No one tech here is doing it for glory. That job is not for warriors but for real hard workers.
                        I do appreciate when someone has an idea/knowledge/experience and shares, it gives me more than my thoughts.
                        • jabatt
                          • Apr 2014
                          • 15
                          Hi Guys,
                          1)Initialize Address Books, Network Settings, Job History, Copy Program:Utility – Admin – Security Settings – Security Details – Initialize – (select all) OK – Confirm YES – OK – Turn Power OFF/ON2) Overwrite all data on the HDDUtility – Admin – Security Settings – HDD Settings – Overwrite all data (select mode**) – Delete - Confirm Overwrite - OK
                          Now the C224e doesn't copy, scan or print.
                          If you try to copy, it will scan the original in, the memory % goes down to 99 and it just sits there doing nothing!
                          Before we noticed the issue, we had another Bizhub come back to the shop, this one was a C284e. We did exactly the same reset procedure and now we have 2 coffee tables!
                          My initial thought is MFP board, but really? We knackered the board with the reset?
                          But the reset is the only common factor.
                          What do you guys think?
                          Tam
                          BHC284e has a reset tool.
                          • allan
                            RTFM!!
                            • 5462
                            Originally posted by jabatt
                            [ATTACH=CONFIG]42778[/ATTACH]
                            BHC284e SSD copy tool available.[ATTACH=CONFIG]42777[/ATTACH]
                            Hey buddy wrong thread for this.
                            Whatever
                            • Taminol
                              • 171
                              Ok, so I think there could be one more issue that we've managed to inflict on this machine with the reset procedure.
                              We delivered the machine and was struggling to get scanning set up. So as a failsafe I suggested the client temporarily uses the USB port with a flash drive to get their scans. The C224e borings up the message "this function is currently not available" referring to the external memory. When into admin and ensured that the functions were turned on for scan to USB print from USB. They weren't there!
                              the admin setting I did was utility /administrator / system settings /user box settings /external memory function settings and there was only one button available in there which was save document and that was switched on.
                              Has this reset managed to turn another function off somewhere deep inside admin?
                              Thanks in advance
