C552 color registration issue
  • ECA
    • Dec 2014
    • 61
    Hi Guys
    have a colour reg issue on our C552
    ive followed field manual page 728 (18.3.33 Printer 4-color: incorrect color image registration)
    cleaned transfer belt (although not dirty)
    cleaned transfer roller on door
    fuser is brand new.
    but color reg is off. and its not equally off over the entire page. the Y axis is ok at the start, but completely out at the end.
    see attached pic
  • allan
    RTFM!!
    • 5462
    Re: C552 color registration issue
    Any P-codes?
    Whatever
    • ECA
      • Dec 2014
      • 61
      Originally posted by allan
      Any P-codes?
      im a little out my depth
      ive attached all the warnings i can find.
      IMG_20190604_111027.jpgIMG_20190604_111002.jpgIMG_20190604_111013.jpgIMG_20190604_111019.jpgIMG_20190604_111027.jpgIMG_20190604_111038.jpgIMG_20190604_111142.jpgIMG_20190604_111210.jpgIMG_20190604_111221.jpgIMG_20190604_111335.jpg
      • darry1322
        • Oct 2010
        • 817
        Look for the oil can at the bottom of the screen. If there is one, tap it to display any P codes.
        I had something similar that turned out to be the LPH driver board.
        • ECA
          • Dec 2014
          • 61
          L2 L3 L4
          • darry1322
            • Oct 2010
            • 817
            L2 L3 L4
            Those are Life Warnings for M,Y,K imaging units
            • CompyTech
              Super Tech
              • Feb 2011
              • 706
              L2 L3 L4
              Means your color imaging units M & Y and K drum are past end of life. Might want to replace those first and go from there.
              • ECA
                • Dec 2014
                • 61
                It started to happen after replacing the fuser unit
                forgetting those C Y M drums etc. what else can it be?
                I do need to strip down the machine and clean everything. but thats a mission and a half.
                • darry1322
                  • Oct 2010
                  • 817
                  There is a loop sensor just before the fuser entrance that can cause lead to trail color alignment issues.
                  • ECA
                    • Dec 2014
                    • 61
                    Are you able to point me to the location? ref a page out of the field manual if you could please.
                    unless anyone knows of a service guy that covers Cornwall,UK
                    • darry1322
                      • Oct 2010
                      • 817
                      It's PS41 and PS42 in the manual. I've never had an issue with them but others have. The picture is with the fuser removed to expose the sensors.
                      • ECA
                        • Dec 2014
                        • 61
                        Cheers
                        i'll look tomorrow.
                        anyway to test? looking at sensor info in service mode?
                        • copier tech
                          • 8221
                          Hi Guys
                          fuser is brand new.
                          see attached pic
                          [ATTACH=CONFIG]42736[/ATTACH]
                          I'd start by removing the transfer unit & cleaning the patch sensors & printhead glass might be all it needs.
                          However if the transfer unit or K image unit are way over life you will get this issue & they will need to be replaced.
                          • mo0651
                            • 1054
                            Does it ever make a good color copy or print? The Fuser sensor usually only has a problem when running multiple pages in a run. If you open and close big front cover, machine
                            runs a quick calibration. Then run a print job. Is registration ok?
                            • tsbservice
                              Field tech
                              • 8064
                              Agree, especially if issue appeared after Fuser change. Check both photo interrupter sensors(they are the same), actuators and spring.
