Konika Minolta Bizhub C220 reg issues
  • Brandon
    • Jun 2019
    • 72
    [Misc] Konika Minolta Bizhub C220 reg issues
    Hi all
    i am having issues with a client with a Bizhub c200 , the print certificates on thick paper 330gms and recently they have issues with the image skewing obviously using the bypass , normal 80gms is fine registration is 100% anything above 80gms "skews" i have replaced the registration roller and bypass feed rollers but still have the issue
    any help or suggestions will be highly appreciated
    thank you
    B
    • 36935
    Re: Konika Minolta Bizhub C220 reg issues
    Try posting in http://www.copytechnet.com/forums/konica-minolta/
      • 22960
      It doesn't matter if it's a bizhub C200 or a bizhub C220 ... neither will print 330gsm media. I really hope it isn't a bizhub C200. =^..^=
      • Brandon
        • Jun 2019
        • 72
        Originally posted by Brandon
        Hi all
        i am having issues with a client with a Bizhub c200 , the print certificates on thick paper 300gms and recently they have issues with the image skewing obviously using the bypass , normal 80gms is fine registration is 100% anything above 80gms "skews" i have replaced the registration roller and bypass feed rollers but still have the issue
        thank you
        B
        sorry 300gms not 330gms
        • allan
          RTFM!!
          • 5459
          So a C200 or C220?
          Whatever
          • Brandon
            • Jun 2019
            • 72
            c200
            • copier tech
              • 8107
              c200
              You expectations are too high on this very old model.
              Like using a 20 year old car with 200k on the clock as a taxi, customer asks you to turn on the AirCon lol
