BIZHUB 215 error C3452 right after power on
  • bouzaydy
    • Dec 2017
    • 21
    HELLO
    Anyone can help me to fixe this
    thnx in advance
  • copier tech
    • 8131
    Re: BIZHUB 215 error C3452 right after power on
    Code
    C3452
    Description
    Warming-up failure (sub)
    - The thermistor/2 (TH2) detected that the temperature of the surface of the fusing roller did not reach the specified level even after the lapse of given period of time has passed during warm-up.
    Remedy
    1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and MFPB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change MFPB. 6 Change DCPU.
    I would start by replacing the fuser unit.
    • Woxner
      • Jul 2011
      • 841
      did you try and reset this first? power surges can set this off
      • bouzaydy
        • Dec 2017
        • 21
        Originally posted by woxner
        did you try and reset this first? Power surges can set this off
        yes i do
        i think there is somthing wrong on dc
        • Toxic
          • 697
          What is counter?
          Did fuser get warm at all?
          I would first try replace fuser or at least check termistors,it could be toner build up on them and act as isolator.
          • bouzaydy
            • Dec 2017
            • 21
            Originally posted by Toxic
            What is counter?
            ok
            all is fine
            i think i need to performe a firmware update so if someone here can send me a copy of
            thnks
            • Toxic
              • 697
              How did you come to that conclusion?
              Did you try replace fuser,i never had problem with firmware on this low segment machines and dont think that is problem.
              You can find firmware on Infohub if you want to try that.
              • bouzaydy
                • Dec 2017
                • 21
                • bouzaydy
                  • Dec 2017
                  • 21
                  ok friends i got it
                  if you all is right on BZ and the error is still come right on power even if you reset the error service mode do this
                  PRESS Stop ===>power on ===>until it power normaly or an ather error come back
                  if it still come back that mean you have something wrong
