Bizhub C-454e, backdoor service entry?
  • Oystercopy
    • Oct 2009
    • 626
    I know there's got to be a way to get into service mode, other than the standard method. My machine is locked up in the "wrong USB stick" mode and I can't get it out...
    Thanks in advance!
    OC
  • copyman
    Owner / Technician
    • Sep 2005
    • 4789
    Re: Bizhub C-454e, backdoor service entry?
    See if machine will start with USB service port door open but no USB stick in it. This has worked for me in the past. Tape it open until you are able to sort out your issue, i.e. format hdd, etc.
    • Woxner
      • Jul 2011
      • 854
      try power sw off. turn on main sw and hold top power button down for a few seconds the stop 22200 extra service mode
      • emujo2
        • Mar 2017
        • 1579
        Thanks in advance!
        OC
        I believe if you launch trouble reset and enter the service mode key sequence (w/o hitting trouble reset icon) this will put you into service mode.
