AccurioPress 6085 C-2470
  • DigiMan
    • Jan 2013
    • 262
    [Dead] AccurioPress 6085 C-2470
    Hey everyone,
    Got myself in a pretty bad pickle today.Long story short co-worker went to clean the coronas(M/Y)
    and uppon closing the front door when finished(he didnt pull out the process unit)he got a persistent C-2470.
    Heres what i did today:
    Cleaned the hell out the machine(contacts in the back,springs etc).
    Checked with I/O and the front door open everything turns manually(Drums,devs etc).
    Checked 25-00 for front door sensor,checks out.
    Checked 43-00 for DCPS/1,checks out.
    Checked 29-07 for process unit detection mechanism/2,checks out.
    BUT! 29-06(process unit detection mechanism/1)doesnt work,it gives constant zero upon pulling out and putting in the process unit.
    Note:The code pops immediately after you close the main door,no warm ups no nothing.
    Service manual says to change the wirings but how could the wirings fault without even messing with them?Tried to measure the corresponding CNs in the printer board but the terminology on the connectors is beyond my skill so didnt do anything..
    I already ordered a new PRCB and wirings but i would like some opinions on the matter because if these both wont work im not gonna hear the end of it from the customer...
    Thanks guys
    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
    • 23006
    Re: AccurioPress 6085 C-2470
    If I were to make a guess, I'd say that there is a bent pin on the modular connector for the process drawer. I cannot find any sort of interlock system for the process drawer, so perhaps it checks the continuity through the modular connector.
    Logically it might be looking for a loop on the drawer side, but it may use a specific component as simple as a photointerrupter to determine if that drawer is closed.
    I have a colleague that spent a week with a bizhub 1200P that was giving intermittent fuser codes (6 or 8 times a day). His problem turned out to be a damaged pin in the fuser modular connector. The error cleared every time, and returned within the hour.
    So the problem might be the harness in the back of the machine, or the drawer harness, or the PRCB. Your co-worker may have just been unlucky enough to rest his hand on the machine that day, nothing more than that.
    Please let us know how it goes. =^..^=
    • DigiMan
      • Jan 2013
      • 262
      Thanks for the input BC,pretty sure it uses the connector for the feedback as i had today another co-worker on a 6085 and he got an output on the 29-06 just by locking unlocking the process unit..does that require also a signal from the PRCB to give the intended result?Not sure to be honest and quite frankly kinda tired to even think today considering the amount of s@#t i just heard from the owner..Alas il just try to stay positive and start changing parts..
      P.S sorry for the rant
      • tsbservice
        Field tech
        • 8003
        Man, can't help cuz I'm not seeing this machines at all, but wish you good luck!
        Everyone has one of that bad days, just stay positive and the sun will shine another day. Look.
        I hate when can't fix them right now, still winning almost every game. When you play games you are not supposed to win all of them, yet you manage to fix most problems. Regroup and come back stronger with more ideas and more knowledge, that helped me numerous times.
        BR, tsb
        • tsbservice
          Field tech
          • 8003
          DigiMan, found that see if it helps, basically it's what BC recomended :
          Error
          C-2470 during installation.
          Root Cause
          Loose interim connector on the front of the process unit.
          Workaround/Fix
          Verify interim connector (located on the front of the process unit) shown below is properly connected.
          P.S.
          Also manual states if 29-06 checked NG but
          29-07 checked OK, you should check connectors and wiring, which in turn means, no boards are faulty.
          I
          f I bet my money probably will go for a bent pin.
          • DigiMan
            • Jan 2013
            • 262
            @tsbservice thank you for the kind words,always nice to hear these things from techs with way more experience than myself.
            It boggles the mind sometimes when you try your best to help someone and still get s#@t for it.
            In any case,i tried to find the bulletin you mentioned but could not find it,at least in infohub.
            Could you send the picture of the connector shown in the bulletin?
            Thnks a ton again
            • tsbservice
              Field tech
              • 8003
              I don't know where bulletin is in infohub, sadly mentioned picture can't be open/or view otherwise I will upload it for you.
              • DigiMan
                • Jan 2013
                • 262
                Darn,PrintScreen?
                • tsbservice
                  Field tech
                  • 8003
                  Originally posted by DigiMan
                  Darn,PrintScreen?
                  Nah, won't open at all, that is all I can see, tried with 3 different browsers, but attachment just misses:
                  C2470 mentions two wirings:
                  -A92WN147
                  -A92WN123
                  They can be found in parts list on page 62 and 131, see if you can find something similar in machine.
                  It's CN1103
                  • tulintron
                    • Jul 2014
                    • 668
                    Good Morning. I'll try to give a kick to help.
                    Check the ICP's of the PRCB.
                    Presenting the error as soon as the door closes, there is something wrong with the electronics.
                    • tulintron
                      • Jul 2014
                      • 668
                      Check this image...
                      • DigiMan
                        • Jan 2013
                        • 262
                        @tsbservice I remember checking them yesterday but maybe i missed it,i'l check again.Thnks so much!
                        @tulintron Yeah forgot to mention that that was my first guess as well and i checked everything without finding a fuse blown sadly..
                        • tulintron
                          • Jul 2014
                          • 668
                          Connectors
                          • DigiMan
                            • Jan 2013
                            • 262
                            Originally posted by tulintron
                            Check this image...
                            Damn,been so long i fiddled with fuses i didnt even know the book had a list of them.I did check a bunch of them but i definitely did not check all of those.Interestingly enough ICP1 connects to the ADU lock solenoid which in turn if you go to I/O check 29-06 it connects with that too which is the only check that returns abnormal when you close the process unit,but what does the adu has to do with the process unit?
                            • tulintron
                              • Jul 2014
                              • 668
                              The connection between the Processing Unit and the ADU is that it does not open both at the same time.
                              Process unit open, solenoid does not open ADU.
                              ADU open, does not open Processing Unit.
                              The tests that you performed and gave positive, do not need the unit closed.. With lid open, unit open, you can test them. The motors are not in the unit.
                              I may be wrong, but everything indicates PRCB. I hope it's really an ICP.
