bizhub c280 SMB2 support in firmware
  • printnewb
    • Jul 2019
    • 2
    Hello, recently I acquired a bizhub c280 machine. I managed to set it up to scan to smb but I had to downgrade the minimum SMB version to smb1 and that's rather insecure w.r.t worms and other nasty viruses. My question is if KM has released a firmware which supports at least SMB2 and where can I obtain said firmware? Looking at the current firmware version the machine shows:
    MFP Controller A0ED0Y0-0100-G00-D2(00), is there a newer one?
    Thanks in advance.
  • tsbservice
    Field tech
    • 8081
    Re: bizhub c280 SMB2 support in firmware
    Old machines, I think there is only one Special FW version which is indicated as:
    • rrrohan
      • Sep 2011
      • 1977
      for the very few clients on C360 range we just switched them to FTP instead
      • JDR
        • Jan 2015
        • 82
        just enable back SMB v1
          bad advise...
          SB1 has problems blocking virus and malware
          do that and you boss might be involved in a lawsuit
          • tsbservice
            Field tech
            • 8081
            Did you really read what OP said?
            Guy managed to do Scan to SMB but he is aware of SMBv1 vulnerabilities as Phil mentioned.
            I try to switch Scan to Box instead of SMB even on newer models, less problems.
            • copier tech
              • 8236
              How about scan to email as a workaround?
              I have a few of these using gmail (fw update needed first)
              • Synthohol
                Certified Konica Expert
                • 5922
                no dice for the C280...
                time for a machine from this century
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  Just curious if you then use Box Operator to access the scans from a PC vs. the convoluted, multiple clicks and screens to navigate to the Box page in PSWC. We install Box Operator in instances where we can't get scan to SMB working or if there is a security concern. Of course, the only drawback on using Box Operator is that it would require admin access on the PC to install it.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • tsbservice
                    Field tech
                    • 8081
                    I just map shared folder. Have complete setup, but not in English.
                    • emujo2
                      • Mar 2017
                      • 1579
                      Again..what protocol is used to communicate...SMB1 or 2? As the poster mentioned. SMB1 is considered a NoNo due to a lack of security..SMB2 will not be offered on the C280..FTP(s) or email would be the best choice.
                      • tsbservice
                        Field tech
                        • 8081
                        This is out of context, I never said I use SMB1 on C280 or new models. There's is only one special FW version which KM indicated as possible to work with SMB2.
                        Regards
                        • printnewb
                          • Jul 2019
                          • 2
                          What do you mean by "map shared folder"? In any case I eventually settled for using SMB1 since the server hosting is based on samba rather than windows (all windows machines in this network do use SMB2 at least).
