Konica C1060L Bizhub Image problem Issue
  • fakhritraders
    • Jun 2019
    • 5
    [Misc] Konica C1060L Bizhub Image problem Issue
    Hello
    Need to resolve this problem, if anyone knows how to solve this problem, I have Konica C1060L, Machine Counter 500K recently replace all 4 drums, developer, transfer belt & blade, charging corona, all OEM, did Glass scan calibration, don't have an external Fiery, now the problem is images are printing darker, & halftone screen are not visible from 3%-15%, on picture, image density becomes dark. Density measurements setting are on 0. ThanksImage3.jpg
  • Toxic
    • 697
    Re: Konica C1060L Bizhub Image problem Issue
    After replacing this parts i only do toner density sensor init,blade setting mode,color registration auto adj., and auto gamma adjustment and so far no problems.
    How you do calibration from glass?
    • fakhritraders
      • Jun 2019
      • 5
      Thankyou for reply, I have not done blade setting, i will do that, calibration done with Scanner glass with print from printer gamma offset auto.
      • fakhritraders
        • Jun 2019
        • 5
        Perform all this steps again, but nothing happens still same result.
          • 23007
          Are you using aftermarket toner? =^..^=
          • fakhritraders
            • Jun 2019
            • 5
            Thanks for reply, Toner we purchased is from Konica local Distributor, many service options has been done from service manuals, but problem is still same.
            • raplma
              • Mar 2017
              • 139
              I confess to not knowing the c1060L, so ignore if not applicable. but check it's colour registration assembly.
              We had a c6501 and several c451's that used to do do this and in both cases it was the colour registration sensors, or IDC sensor.
              Took them out, gave them a good clean, making sure the gate springs are connected, the sensors are clean and in the case of the c6501 the felt pads were cleaned.
              We also have a c5501 and c7000 which both have the same set-up but of course the c1060 being the next generation this may have all changed.
              • seximibabay07
                • Mar 2013
                • 59
                pls: Any one for share the Konica C1060L Bizhub Service Manual???
                • Synthohol
                  Certified Konica Expert
                  • 5824
                  normally i would hound you to become a contributor but its thanksgiving here and im feeling generous.
                  ck your PMs
                  • seximibabay07
                    • Mar 2013
                    • 59
                    ck your PMs
                    god bless U...
                    • lucky13
                      • May 2008
                      • 125
                      have you tried resetting max densities all to factory {recall standard data factory} then re-adjust
