C3070L fusing belt problem
    • 23009
    #16
    Re: C3070L fusing belt problem
    Congratulations on your success! =^..^=
      it took some time ( as the really stumpper ones do )
      but congrats on the success ... you'll never forget this one I'm sure!
      • Aleksandar KM
        • Jul 2019
        • 13
        #18
        Thank you i will surely never forget it
        And again thank you all for the support and help.
        Cheers
        • khaled_mohamed
          • Mar 2019
          • 6
          #19
          Please we need photo to locate where this spacer
          thanks in advance.
          Originally posted by DigiMan
          Hello!
          Its a known problem with some of the first models of the series,you need to apply a certain spacer below the lower fusing belt
          from the side thats it tearing to solve your problem,dont have the part no available at the moment but i can have it tommorow if you can wait.
          Dont worry its nothing difficult to apply just dont replace another belt until then :P
          Edit:Scratch that found the number 9981001296 though i dont have at the moment pictures on how to apply.I'l definitely have these tomorrow!
          • DigiMan
            • Jan 2013
            • 262
            #20
            Originally posted by Aleksandar KM
            Hello everyone,
            The spacers solved the problem.
            I waited some day to make sure it was ok that's why i didn't write immediately.
            Thank you very much DigiMan for all the help.
            Kind Regards
            Sorry took so long to respond was away on leave for the summer!
            Glad to hear it Alex and thanks for letting everyone know of the results!
            I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
              thanks in advance.
              IT MIGHT HELP IF YOU -=READ=- ALL COMMENTS IN A THREAD BEFORE ASKING AN ALREADY ANSWERED QUESTION!!!
              Originally Posted by DigiMan
              Maybe,to be sure you can remove the lower fusing roller and check for the spacer if its there.
              Honestly try the countermeasure its not a big deal,its cheap its easy to install.
              Frankly im pretty sure the problem origins from the soft roller(the pink one)from the fusing belt assy.
              In any case try the countermeasure and let us know how it fairs.
              IF Digiman said " lower fusing roller and check for the spacer if its there. " WHERE would one suppose the spacers would be?
              • Rolandito
                • Aug 2007
                • 91
                #22
                I found this.
                Maybe It can help to someone, who is in need
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  #23
                  My service manager and I are trying to find a bulletin or any info on this issue as we just had a C3070 in the field with less than 200K do this same thing. I haven't been onsite yet but wanted to try and find out what the bulletin is if there is one of if this spacer thing was just what someone figured out to remedy the issue.
                  Yes, Phil B. I did see where it says remove the lower roller to check for the spacers but I have no clue what they look like to determine if they are there.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • tsbservice
                    Field tech
                    • 8020
                    #24
                    Check KB for KBA00041506. There's no spacers but screw to be addressed.
                    • srvctec
                      • Oct 2009
                      • 827
                      #25
                      Originally posted by Rolandito
                      I found this.
                      Ah, OK. I was just going by the posts that kept mentioning spacers. Thanks to the pdf in the post by Rolandito above mine, I was able to see what the issue was and the front shoulder screw was loose to the point of partially out about a turn, causing the issue with a gap in the frames (rear one was just not very tight but no gap in the frames). Replaced the belt and made sure to get both the front and rear screws very tight and centered in the holes so the issue hopefully won't happen again. This one had 229K on it. Can't believe it went that far before having an issue unless the screws just worked their way loose.
                      • DigiMan
                        • Jan 2013
                        • 262
                        #26
                        Although i have encountered the issue with the screw,two times that happened the machine popped fuser code(dont remember which one).
                        THe spacer that i talked about is small like the spacers we used to put on the paper cassetes on the ol 250's to help them close properly.
                        If you ever had a fuser from a production machine dissasembled(the lower fusing roller)you can immediately recognize the spacer if it is there.
                        Its right below the right or left bearing.If not just order it,a chewing gum probably costs more.
                        Hope this helps further.
                        • srvctec
                          • Oct 2009
                          • 827
                          #27
                          Thanks for the reply. Are you in Europe or somewhere other than the US? I ask because my service manager searched quite extensively without luck, trying to find the part number you have listed in the second post of this thread (9981001296). No way to order it unless the number has changed or something. I even searched through the 32 KMBS Price Lists (all the parts available to order) I have dating back to 2002 (in case it was an old part repurposed) and the part number isn't in any of them either.
                          • tsbservice
                            Field tech
                            • 8020
                            #28
                            Just FYI.
                            A newly designed fusing roller/1 (p/n A9VE720111) is being released to resolve the issue with tracking of the fuser belt.
                            Be aware that if the machine has a new style fusing roller/1 the spacer must be removed.
                            • kandod
                              • Mar 2010
                              • 58
                              #29
                              Interestingly you keep mentioning that spacer, can you give some info on how to accuire one of theese, because no trace of it in the net.
                              • srvctec
                                • Oct 2009
                                • 827
                                #30
                                Yeah, the part number given in this thread isn't even close to what it actually is here in the US, anyway. There was a technical bulletin that came out on Nov. 4th, 2019, bulletin# 11810 with all the correct info and exactly how to test for the issue to see if you even need the spacer. The spacer is FOC. This is also the bulletin that mentions the new roller.
