C3070L fusing belt problem
  • kandod
    • Mar 2010
    • 58
    #31
    Re: C3070L fusing belt problem
    Originally posted by srvctec
    There was a technical bulletin that came out on Nov. 4th, 2019, bulletin# 11810 with all the correct info and exactly how to test for the issue to see if you even need the spacer. The spacer is FOC. This is also the bulletin that mentions the new roller.
    Can you please give me info or quote here the procedure to check for the issue. I dont have access to konica service site, and really would like to know how to avoid belt replacement on a low counter but 2017 produced AccurioPrint 2060l.
    • tsbservice
      Field tech
      • 7910
      #32
      Just FYI:
      A newly designed fusing roller/1 (p/n A9VE720300) has been released.
      Check tech bulletin for judgement if machine needs new one.
      • khattab.al.masry
        • 212
        #33
        IT MIGHT HELP IF YOU -=READ=- ALL COMMENTS IN A THREAD BEFORE ASKING AN ALREADY ANSWERED QUESTION!!!
        Originally Posted by DigiMan
        Maybe,to be sure you can remove the lower fusing roller and check for the spacer if its there.
        Honestly try the countermeasure its not a big deal,its cheap its easy to install.
        Frankly im pretty sure the problem origins from the soft roller(the pink one)from the fusing belt assy.
        In any case try the countermeasure and let us know how it fairs.
        IF Digiman said " lower fusing roller and check for the spacer if its there. " WHERE would one suppose the spacers would be?
        THANK YOU MR:REPUTATION
        • khattab.al.masry
          • 212
          #34
          where are you Mr: Reputation?
          • Jayson
            • Apr 2020
            • 5
            #35
            Hi all ,
            After replace with new fusing roller/1 (p/n A9VE720300), the fusing belt still shift to maintenance side ..any advice ?thank you
              • 22927
              #36
              Have you looked at any of the previous posts in this thread? =^..^=
              • Jayson
                • Apr 2020
                • 5
                #37
                Yes , because this new fusing roller/1 (p/n A9VE720300)without spacer is solve the fusing belt shifting .So mean this new fusing roller also cant work ! Need to put back the spacer ?
                  • 22927
                  #38
                  Yes, re-install the spacer. =^..^=
