C558 Tray 3 jam and noise
  • jwai
    • May 2018
    • 517
    Hi guys,
    I have a C558 that sometimes jam on tray 3, and strange noise while feeding on that tray.
    I tried to replace the rollers, one way bearings and driving motor of that tray however the issue still stay.
    Any suggestions for this case?
    • 15011
    Re: C558 Tray 3 jam and noise
    Originally posted by jwai
    Hi guys,
    Jam code?
    Paper size?
    Paper orientation?
    Is it an LCT or universal tray?
    • kingarthur
      • 1390
      I had one that the shaft that the DFPV roller sits on was actually bent slightly
      • jwai
        • May 2018
        • 517
        Jam code?
        Paper size?
        Paper orientation?
        It's A4 crosswise , and there is PC-215 ( 4 universal trays ).
        • jwai
          • May 2018
          • 517
          You said the shaft of double feed prevention roller, is A161-5634-00?
          • jwai
            • May 2018
            • 517
            Jam code?
            Paper size?
            Paper orientation?
            Jam code is 20-02.
              • 23010
              bizhub 658e with PC-415, J9901 and J20-02
              How about this? =^..^=
              • jwai
                • May 2018
                • 517
                Thank you for your information, let's try it!
                • jwai
                  • May 2018
                  • 517
                  I tried to exchanged the gears unit with tray 4, the problem seems be solved !
