c3851fs not discoverable on network
  • joe.m1989
    • Apr 2018
    • 14
    we have a customer that has a c3851fs that upgraded from a c224e, which I consider a downgrade tbh. It seems like I can't discover it on either my phone or through windows printer discovery. They need this option enabled for people that print using their cell phones. I looked through the manual, and found that the only solution may be to have the customers download the pagescope mobile app, which isn't really going to work for this customer, has they allow the general public to connect to their network and print to that printer. Is there a specific setting that needs to be turned on, or is the printer pagescope mobile reliant? I showed the customer how to download and use the app, but all they want is simple printing. I know its not my phone because I'm back at HQ and I'm able to see older model printers on my phone's discovery no problem.
  • qbert69
    • Mar 2013
    • 1152
    Re: c3851fs not discoverable on network
    Does the machine have SNMP protocol enabled?[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • joe.m1989
      • Apr 2018
      • 14
      I didn't even think of that. But it does, we use FMAudit for meter obtaining and it reported today, so yes SNMP is enabled
      • Kimi
        • Feb 2018
        • 105
        Are you meaning Windows self discovery?
        • joe.m1989
          • Apr 2018
          • 14
          Its not showing up on either windows discovery or the phone discovery
          • Kimi
            • Feb 2018
            • 105
            Have you checked it has WSD enabled?
            • joe.m1989
              • Apr 2018
              • 14
              Yes it is enabled, I made sure the dwps settings were on. I just remoted in and saw that windows services picked up the printer finally, I'm just not 100% about phones. I'm going to tell the customer that the phone printing is reliant on the pagescope mobile app just to get them situated. Thanks!
              • Synthohol
                Certified Konica Expert
                • 5799
                WSD port printing is a joke.
                Manually set the IP address. Port 9100 raw Never use a WSD port. That's amature hour.
                • guitar9199
                  • Sep 2016
                  • 1099
                  A couple of things to watch for....
                  If they're connecting to a "PUBLIC" network, by default File and Printer Sharing and Network Discovery are turned OFF! Check into that.
                  On the computers, check the Advanced properties for the ipV4 protocol. On the WINS tab, check if it's set to NetBIOS over DHCP. If it is, change it to NetBIOS over TCP/IP. NetBIOS over DCHP doesn't play well with network discovery.
                  While you're on the computer, check the Windows Firewall Advanced Sharing settings, and make sure File and Printer Sharing is enabled for Inbound Rules.
                  ...good luck.
                  • joe.m1989
                    • Apr 2018
                    • 14
                    I agree, and it is set to static. They want this for visitors, not for on site users, as they have no on site IT. Every workstation they have is set to static, along with the printer. Its for visitors.
                    • copier tech
                      • 8132
                      Are you talking about AirPrint?
                      Try updating the FW.
                      โ€‹
