bizhub c3300i/c4000i IU problems
  • femaster
    • May 2011
    • 1511
    #16
    Re: bizhub c3300i/c4000i IU problems
    If I could hijack this thread please.
    I'm having this exact same issue but on a C3350i so far I have replaced 2x yellow IU, 1x black & 1x cyan machine only has 12K total count.
    The machine will call for a toner customer will fit new (genuine) however the message will not clear.
    Fitting a new IU of that colour temporally resolves the issue.
    I can not see any bulletins on this issue from KM?
    I don't think this is related to your problem, but who knows. There was a new bulletin and firmware update released for a number of the i model machines the end of last week. According to the bulletin, one of the resolved items is "Possible Premature IU Failure". I don't think that is what you are dealing with here, but maybe they are very loosely related? Looking at the Firmware information PDF, there are 123 issues that are fixed by the latest release, none of them seem to specifically call out the issue you guys area having though. I've attached the bulletin, and will list the 123 fixes between this and another post because, because there are too many characters for the board to handle apparently.
    Code:
    2.2. Fixed issues
    1. Cannot install/uninstall an external Open API Application if the MFP shifts to the Power Save Mode while a user still logs in
    to the MFP.
    2. When the URL other than http is entered for the URL of the OCSP service, the entered value is cleared instead of displaying
    the error message.
    3. Cannot uninstall MarketPlace from IT6.
    4. If only a single application is registered in the MFP, the application will not activate directly by pressing the APP button.
    5. Even after a job is completed, the message "The panel is illuminated due to a warning." may be displayed for a while.
    6. An error occurs when a copy job is executed with the IWS application.
    7. "C-D706" may occur when updating FW
    8. If the first item of the DHCP option field of the packet received from DHCP server is not DHCP Message Type (53), the
    address acquisition fails.
    9. E301 occurs when users log into MFP using PaperCutMF (browser authentication application) with the MyPanel function
    enabled.
    10. The trouble code field may become blank when the MFP detects the trouble and displays its trouble on the panel.
    11. The specific PDF cannot be printed by Direct Print.
    12. No warning dialog is displayed when paper is jammed during PullPrint.
    13. As MFP is powered on, it displays service mode top menu after auto-transition to self-diagnosis
    14. Panel may freeze when selecting the list box on the screen of the application started from the MFP.
    15. When the MFP is updated by using a specific RDT template, the message "Operation remotely" may keep displaying on the
    screen.
    16. When updating settings from RDT, the MFP may remain in "Operation remotely" state.
    17. When the user authentication is performed, the user may be able to execute TWAIN Scan without SSL/TLS setting.
    18. When the screen of the original size detection error is displayed on the browser, a user cannot go back to the original screen
    by closing the error screen.
    19. After applying G00-73 or later FW, the setting "Prohibit continuous selection of broadcast destinations" cannot be changed.
    20. "+" Symbol cannot be used in IEEE802.1x authentication password
    21. The MFP may not return from Power Saving Mode.
    22. While a user logs in to the MFP and uses the Panel, another user can log in to the MFP from KMMP (KM Mobile Print) and
    perform a scan job.
    23. Only up to 15 search results are displayed when using Address Search function in the Fax Retransmit User Box.
    24. An emulation error occurs during the printing, and the printing job may be deleted.
    25. Although [Personal Data Security Settings] is ON, the destination e-mail address is displayed on the [Job History].
    26. Error occurs when a user changes the default certificate from RDT.
    27. When printing a specific document by PS Driver, an error page is outputted.
    28. When updating FW, the message "This is invalid External Memory" may be displayed.
    29. The shortcut key name is shown as “{}" in the Main Menu Default screen.
    30. When printing a specific document from Mac OS, a part of an image is not drawn and a "limitcheck" error page may be
    outputted.
    31. IC card cannot be registered with [Use opening number] at [User Registration]
    32. Pressing the "Cancel" button in user settings or administrator settings makes the character of setting items larger.
    33. Delete the file saving process of administrator password information
    34. Outputted color becomes vermilion instead of red, and the line width that is outlined in white is thin.
    DipSW No. 188 (bit 2)
    To OFF/ON the function to enhance color by changing the parameter of red color.
    0x00: OFF (Default)
    0x04: ON
    DipSW No. 188 (bit 3)
    To OFF/ON the function to make the line width outlined in white thick.
    0x00: OFF (Default)
    0x08: ON
    35. Receiving a phone call may fail when TEL/FAX Auto Switch is ON under Number Display (Caller ID Display) environment.
    36. It takes time when turning the main power OFF/ON after upgrading FW.
    37. The MFP does not start up due to the error occurred in the CPU board.
    38. Even though LDAP is enabled, "LDAP Search" is not set as default for Address Search function on Basic Style.
    39. Spelling mistakes in items in Administrator settings (Korean).
    40. Destinations for [Scan to Home] are displayed only if "All" is selected on Basic Style.
    41. The MFP may keep sending the same notice of parts life or toner near empty by the fax communication of CS Remote Care.
    The following Software SW setting is required to enable this countermeasure.
    Perform the following setting at the Software SW settings in CS Remote Care.
    (Note) It is not the Software SW setting at System Settings 2.
    [Service Mode] > [CS Remote Care] > [Maintenance/Default Settings] > [Detail Setting] > [Software Switch Setting]: set the
    Software SW as:
    Switch No.: 39
    HEX: 01
    42. Phonetic characters cannot be entered correctly when entering a destination in Korean.
    43. Selecting “No” on Pop-up window ["Operation has terminated. OK to return to the initial screen"] will keep screen white.
    44. Cannot switch the keypad from Korean input to Number input.
    45. Modified a part of German translation.
    46. Vulnerability in PJL processing that allows remote code execution.
    This vulnerability can be avoided by prohibiting FS Command of PJL by the following software switch.
     DipSW No.160 (bit 2)
     0x00: Allow (default)
     0x04: Do not allow
    Note: If you set to "Do not allow", you can avoid attacks using FS Command, but you cannot download fonts and overlays to
    the HDD.
    47. Vulnerability in CGI for Direct Print in Web Connection that allows remote code execution caused by buffer overflow.
    48. When registering a new address in Address Book, Kanji is automatically entered in Furigana field and the registration error
    occurs.
    49. When User Authentication (SafeQ/PaperCut) is ON, the "Customize Home Screen" icon is not shown.
    • femaster
      • May 2011
      • 1511
      #17
      Continuation of last post, Firmware fixes.
      Code:
      50. There is no "Set All" button on [Work Time Setting] of Weekly Timer Settings.
      51. Cannot obtain "Tray 4" information by MIB:prtInputType when PC-417 is mounted.
      52. PDF417 barcode is divided into 5 parts when printing.
      53. When [Account Track Input Method] is enabled, if enter [1] or [2] on the login screen, the screen is transferred to the
      password entry screen in Classic style.
      54. There is a possibility that Server might go down when Server is under service outage.
      55. Side Menu area on Classic Style Mode flashes.
      56. Although [Manual Destination Input] is restricted, it is still available to enter from Hard Ten Key.
      57. Cannot find "hyphen" on Korean Soft Keyboard.
      58. It may take time to go into Administrator Settings when a copy program with a long name is in use.
      59. The display language of PSWC is always English at the first access
      60. When printing a job with a mix of A3 and A4, the MFP does not staple in the specified position.
      61. Expected function does not work even SoftSW No.100-bit6 is enabled.
      Software SW No. 100 (bit 6)
      To OFF/ON the function to enable MDN Response function for i-Fax TX.
      0x00: OFF (Default)
      0x40: ON
      62. An error occurs when scanning a specific document size using the IWS application.
      63. A user may not be able to register User Box information with Data Administrator.
      64. PS error occurs when printing a XTPF-formatted file from a special system.
      65. Unable to staple on A5LEF paper from Bypass.
      66. Not complete data are on the Machine Management List obtained
      67. When printing a PDF file with Duplex/Chapters settings by PCL driver, unnecessary blank paper is mixed into the printed job
      randomly.
      68. When printing a job from HP Output Server, the job is not outputted from the expected tray.
      69. When Counter List is printed at vendor mode, Eco Info is also printed.
      Add "Print/Not print" settings for the detail counter.
      70. The screen does not shift to the print screen even a user press [Print] button on the Web browser of the MFP.
      71. USB time out occurs when printing via USB Print Server.
      Software SW No. 158 (bit 3)
      To OFF/ON the function to detect <esc> E Command as the job separation command.
      0x00: OFF (Default)
      0x08: ON
      72. After the MFP board is replaced, the transaction number returns to  001 and the number of the activity report is not in order.
      [INC000000027668]
      73. The order of a job changes when printing the job under SafeQ environment.
      Software SW No.162 (bit 5)
      To OFF/ON the function to switch the available LDP port from 2 ports to 1 port.
       0x00: OFF (default)
       0x20: ON
      74. Make the Storage and the Fax board remains powered even after the MFP shifts to the power save mode.
      Software SW No. 159 (bit 3)
      To OFF/ON the function to make the HDD and the Fax board remain powered even after the Sub Power is turned OFF or
      the MFP shifts to the power save (Low Power/ Sleep) mode.
      0x00: OFF (Default)
      0x08: ON
      75. The trouble code C-E301 may occur on the machine where the authentication using the card reader is configured and CS
      Remote Care is set.
      76. If a user manually sets [Increase Priority] for a [ID & Print]  job, the intended job is printed at the very last of the print queue.
      77. At 0:00 midnights, the MFP automatically recovers from sleep/low power mode.
      Software SW No. 159 (bit 5)
      It changes the timing to acquire PDM data from the engine.
      0x00: OFF (Default)
       -> MFP does not wake up from sleep/low power at 0:00. (MFP controller does not acquire PDM data during sleep/low
      power mode. MFP controller will acquire PDM data from the engine when wake up from sleep/low power mode.)
      0x20: ON
       -> MFP wakes up from sleep/low power at 0:00. (MFP controller acquires PDM data from the engine even if machine is
      78. The MFP freezes if the PullPrint application is activated when there is a job, with a file name with Hebrew characters and
      hyphens, is spooled.
      79. When [Print: Black Only] is selected, users cannot print from ID & Print User Box.
      80. The LDAP Check Connection button disappears when the LDAP Server is registered in PKI Mode.
      81. Auto Zoom setting does not work on Basic Style mode.
      82. Even if System Auto Reset Time is specified in seconds from RDT and sent it to the MFP, the value is not reflected on the
      MFP.
      83. Outputted postcard is curled when printing.
      <Engine DipSW>
      Engine DipSW No. 61 "ON”: All press
      "OFF”: Light press (Default)
       Outputted envelope is wrinkled when printing.
      <Engine DipSW>
      Engine DipSW No. 78 "ON”: Enable
      "OFF”: Disable (Default)
      84. The native screen of the device gets displayed in Japanese even when a different language is set from the authentication
      application.
      85. The Authentication card was swiped, but the document in ID & Print box cannot be printed.
      86. On the Classic Style screen, part of Fax one-touch destinations may not be displayed.
      87. When a specific device certificate is imported, PSWC cannot be connected with TLS1.2.
      88. Users cannot log in by inserting and removing the card after the MFP returns from the Power Save mode if the card is
      inserted in CU-1(Management Device 2) while the MFP is in the Power Save mode.
      89. The word "HDD" is in the message when importing the Security Setting.
      90. Arabic characters are not printed when printing from a specific application.
      The following symbol sets are added to print Arabic characters.
       - Arabic-8
      - Windows 3.1 Latin/Arabic
      - PC-864 Latin/Arabic
      * You can select these new symbol sets only from MFP operation panel.
       [Utility] > [User Settings] > [Printer Settings] > [PCL Settings] > [Symbol Set]
      91. The screen freezes in a state of displaying the progress bar at 25% while starting up the MFP by turning the Main Power
      ON.
      92. Cannot change search characters on the User Box from PSWC.
      93. When printing Print Counter List, values listed on the Panel are different from those on the printed list.
      94. Even if you set password input when updating FW, when panel calibration is done with USB, FW is updated without entering
      password.
      95. When a user connects to PSWC from Bookmark, the display language is changed to English.
      96. IISW Machine Update on [Administrator] mode fails.
      97. Printed stamp is unreadable when printing a PDF which contains a stamp by Direct Print.
      98. Hyphen cannot be input at [Tel/Fax Number] by panel keyboard.
      99. If Software Keyboard is repeatedly pressed by Remote Panel, the screen transfers to the Home screen.
      100. Displayed message of scan results of TWAIN jobs on the Panel is different from the one on PSWC.
      101. Some items in Time Adjustment Setting are not saved.
      102. The actual behaviors of the MFP are different from those specified in Image Log Transfer settings.
      103. No thumbnail image is available in Secure Print User Box.
      104. Scan to SMB fails sporadically when using SMBv1.
      105. Even [Bypass Tray Overwrite Settings for Print PC] is set to  [Driver Priority], the warning that the paper size is mismatched
      is displayed just before outputting the custom size paper when printing Mixed Originals of [A4/custom size] from the PC.
      DipSW No. 142 (bit 5)
      To OFF/ON the function to prevent the MFP from stopping a job due to the paper size mismatch before outputting the
      custom size paper when printing Mixed Originals of the custom size paper from the PC.
      0x00: OFF (Default)
      0x20: ON (The warning of paper size mismatch is displayed before printing Mixed Originals of the custom size paper.)
      106. Popup screen does not appear on Home screen of Basic Style mode even if USB memory stick is inserted to MFP.
      107. When printing the specific PCL data at MFP, the border line is shifted and printed.
      108. Cannot move to OpenAPI Setting from PSWC if German is selected as the language.
      109. Any number may not be entered by key-pad.
      110. The distribution of Movie Data is not available via RDT.
      111. C-E301 may occur when the machine updates the firmware to G00-73 after imported the setting data from predecessor.
      112. The MFP with French setting freezes when [Print Information] under [Utility] is pressed.
      113. Entries made using an external keyboard are not reflected in the running Browser Integrated Application.
      114. "Customize Home Screen" icon is displayed for an instant when a user logs in to the MFP.
      115. Output results are different between the initial FWs of IT4 like G20-60 and the latest FW.
      116. The default value of search type in [Address Search] function is not correct.
      117. The card reader becomes unresponsive from the 2nd login when the same card is used consecutively for login.
      118. The setting value of Post inserter imported via RDT is different from the one obtained from the MFP.
      119. Values of "Stabilization" items on the Machine Management List are different between the printed list and the CSV output
      list.
      120. When restoring backup data "Are you sure you want to start the Restore operation from the Server?" Message is displayed
      as "Cover Sheet Feeder"
      In addition, the message when restoring is displayed in German.
      121. [SMB Host Name] cannot be changed at [SMB Server Settings]
      122. The sender name is garbled on the received Fax
      123. User is able to enter Service Mode without entering CE password.
      • copier tech
        • 8169
        #18
        [ATTACH=CONFIG]46790[/ATTACH]
        Code:
        2.2. Fixed issues
        to the MFP.
        the error message.
        enabled.
        screen.
        perform a scan job.
        outputted.
        0x00: OFF (Default)
        0x04: ON
        0x00: OFF (Default)
        0x08: ON
        Software SW as:
        Switch No.: 39
        HEX: 01
         0x04: Do not allow
        the HDD.
        occurs.
        • and
          • Oct 2011
          • 96
          #19
          B6 firmware resolve only this
          2.2. Fixed issues
          1. It may take long time to start up the MFP in case the network cable is not inserted into the MFP.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            #20
            B5 firmware does address the high toner consumption and iu destruction issue. If its loaded on a machine with already partly destroyed iu you will still need to replace it when it fails but after that point it should be fine. The duration of agitation of the toner /dev mixture has been modified to stop incorrect readings from memory.
            There are of course other reasons for ius to fail, ie loss of drum charge and solid pages of the relevent colour but these are physical issues that you need to find and fix, not software.
            • JDR
              • Jan 2015
              • 82
              #21
              Same problems with IU too Magenta and yellow, like you.
              Nothing else to do than replace these faulty UI..
              B6 not available here too.
              Can anyone share this fw please ?
              • B0265
                • Jan 2007
                • 718
                #22
                This is not mentioned at all in the program release information, have you found this in a bulletin?
                • Bix
                  • Apr 2018
                  • 1421
                  #23
                  I do not think it will be mentioned in a bulletin otherwise it would start the valaganza of requests for the guarantee
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    #24
                    It's not mentioned, but the fix IS in this fw.
                    • HoonBoy
                      • May 2011
                      • 130
                      #25
                      • B0265
                        • Jan 2007
                        • 718
                        #26
                        So B5 contains a more permanent fix than G00-4E/G00-7D?
                        • B0265
                          • Jan 2007
                          • 718
                          #27
                          Does anyone have this bulletin: KNOVA-PS "PSKM_BT2016005EN" ?
                          I can't find at KNOVA (Europe).
                          • Sysco
                            • Mar 2010
                            • 43
                            #28
                            Inmy field I have 4 machines which give the following error (2555).
                            Allthis machines have blurred image with magenta, and of course themagenta TCR is below 6.5%.
                            Onemachines I change the TCR level history to +3 which is the maxsetting.
                            Thismachines run 2 days (not dropped the 2555 error code) after theyempty the new toner whick is 6K toner if I god to know.
                            SoI relese this machines and order the new IU unit which is not to comein this time.
                            Everymachines have G00-53 fw.
                            Thelast information is in this case need to update the fw G00-B5 whichis not the last fw.
                            Soif the IU will arrive to me I change the IU and flash the fw.
                            • Bix
                              • Apr 2018
                              • 1421
                              #29
                              The last (and important) firmware is G00-E9
                              • Sysco
                                • Mar 2010
                                • 43
                                #30
                                I think I have got many machines trying the correct fw.
