bizhub c258 fixing unit
  • mihai
    • Aug 2019
    • 4
    Hy, I have a bizhub c258 which at a higher job, starting with the 18-20 copy starts to stop fixing the toner, what could be the cause?
    Thanks for the help
    • 23006
    Re: bizhub c258 fixing unit
    What media type are you using? What media type is the machine set to? =^..^=
    • Synthohol
      Certified Konica Expert
      • 5820
      lol, you want details BC?
      thats a reach! hehehe.
      • tsbservice
        Field tech
        • 8007
        Post counts on consumables.
        Are you using original toner or compatible?
        Kinda lame question but I'm in a good mood after holiday and will show mercy
          yeah..and I've been trying to be a more kinder ... gentler ... "Dentist" hence the reason I haven't jumped in to comment before now.
          • tsbservice
            Field tech
            • 8007
            I think you should feel better now, it works atleast by my opinion.
            On a sidenote, I must admit sometimes old grumpy Phil is missed badly when they shout out loudly their nonsences and complete ignorance, but overall congrats on been cooler and easy.
            • CompyTech
              Super Tech
              • Feb 2011
              • 706
              Had this problem before. Ended up being the power supply. The kicker was the power supply and MFPB had been changed before because lightning hit the building and took them out.
                "Grumpy Ol' Phil" takes those as kind words.... I guess?
                • tsbservice
                  Field tech
                  • 8007
                  As I said I'm in a good mood
                  Has been working with some Supreme techs(for me) and engineers, all they have their issues.
                  Gotta love people knowing their stuff, no matter what or if.
                  • mihai
                    • Aug 2019
                    • 4
                    Hy, Thanks for the reply. The settings are fine, plain = plain, I replaced the fuser, it does the same. Fuser placed on another copier works correctly. Has the latest firmware ..
                    • mihai
                      • Aug 2019
                      • 4
                      Hy, Thanks for the reply. Original toner ..
                      • tsbservice
                        Field tech
                        • 8007
                        Why in the world you skip that information from initial post is beyond me.
                        Anyway in that case I would think of what CompyTech said - power supply, it may be floating under some load.
                        • Synaux
                          • Mar 2012
                          • 1224
                          Soooo.... does this mean you are using something like 20lb digital copier paper??
                          Have you tried, thick 1, thick 2, thick 3, or thick 4?
                          • mihai
                            • Aug 2019
                            • 4
                            Hi, thank you all, I have replaced the source, the same problem, but I removed and replaced all the connectors on the logic board and the problem disappeared. So an imperfect contact ...
                            • tsbservice
                              Field tech
                              • 8007
                              Good finding and Thank you for follow-up.
