C364e cannot authetificate account tracking department id
  • denvertan
    • May 2019
    • 100
    [Misc] C364e cannot authetificate account tracking department id
    First time trying on the account tracking and also user authetification.
    Both failed without single success login.
    What did I missed?
    Please point it to me, Thank you.
    Setting inside Administrator mode
    1. User Authentication/Account Tracking > General Settings
    2. Account Track > ON
    3. Account Tack Input > Account Name & Password Only
    4. OK > YES > OK
    5. Account Tracking Registration > select box 001 > Edit
    6. Input Account Name as test, password 1234567890 > OK
    7. Out from Administrator Mode
    8. Try login with test and password 1234567890
    9. Get this Authentication failure
    Never successfully login even once.
    *** Apology for my typing error****
  • Leyahné
    • Feb 2016
    • 44
    Re: C364e cannot authetificate account tracking department id
    Just use authentication and make sure you use the correct drivers.Update in the config section of the driver, make sure the obtain settings you have installed the IP for upddate
    Sent from my SM-N960F using Tapatalk
    • denvertan
      • May 2019
      • 100
      The problem is it cannot even login at the MFP it self.
      • Synthohol
        Certified Konica Expert
        • 5905
        Did you enable both act track AND authentication?
        Just pick one.
        Test
        Try enabling the other
        Test
        Check credentials for authentication maybe a bad or missing entry.
        Do not authenticate to external server.
        • denvertan
          • May 2019
          • 100
          Just pick one.
          Test
          Test
          Tried, enable account only, user id only, both. All no luck even with password is 123.
          Anyone know how to disable this ?
          Administrative > Authetication Device > General > Card Authetication.
          • Synthohol
            • 5905
            SERVICE MODE stop 9 or stop 0 Clear
            vendor mode turn off
            • emujo2
              • Mar 2017
              • 1579
              I thnk youve got something confused...
              Account track can be name/password, or password only..If name and password, name is case sensitive
              If you have account track turned ON, password only, then when you register the account you will need to put in name and password, but when they access the machine they should only need password. User authentication can really mess this up if turned on..Be sure this is OFF. E
              • denvertan
                • May 2019
                • 100
                I have tried
                1. User Authetication only
                2. Account Tracking only
                Both did not work at all.
                • Woxner
                  • Jul 2011
                  • 854
                  is the hdd in the machine. when you turn on account track or authen it on it should ask if you want to clear the hdd. this all sits on the hdd
                  • denvertan
                    • May 2019
                    • 100
                    It did show the message that all data will be clearer then I proceed with "Yes" then "OK"
                    What I suspect is the machine is set to only card authentication only. Yet, the option suppose to be there is hidden.
                    How can I enable it ?
                    Missing option 8, how to enable it ?
                    • rrrohan
                      • Sep 2011
                      • 1977
                      [ATTACH=CONFIG]43305[/ATTACH]
                      Well I've never seen a device using account track be able to login with cards. You might be able to do it using keyboard wedge mode but I doubt it.
                      In CE mode billing settings is management function choice set on "UnSet"
                      • denvertan
                        • May 2019
                        • 100
                        CE mode = Service Mode ?
                        I am new to Konica Minolta copier, please tip me a bit more.
                        • emujo2
                          • Mar 2017
                          • 1579
                          You are looking for the billing modes that can be used to enable/disable various card readers or key counters. This is a special key sequence to access that screen. Was this machine used when you got it? Any chance it was in a CAC/PIV environment? E
                          • oldschool
                            • Mar 2007
                            • 245
                            As Synthohol stated, Stop 9 once in service should bring up built in billing mode.
                            Not relevant to your question but worth mentioning...
                            For C3350/3850/4050/4750 press 22200 to access billing mode.
                            Jamex Tech Support: Saving the world one phone call at a time.
                            • denvertan
                              • May 2019
                              • 100
                              Billing Mode is set to "Unset".
                              But error still persist.
