RU-513 / FS-534
  • copyman
    Owner / Technician
    • Sep 2005
    • 4788
    RU-513 / FS-534
    Anyone else having the message to close the RU-513 Transport bed door? If you put slight pressure on door or put a ream of paper on top of door it's fine. Just got a call for 3rd one in a month. I had a bunch of RU-513's so just swapped them out. Now starting to wonder if this will become a problem.
    I looked at the 2 I brought back to shop and they look fine. No adjustment for the interlock sensor and typical sensor tests good. Haven't replaced a sensor in years. It does seem like the design doesn't allow the door actuator to block sensor enough. Might look into modifying some way unless someone else has a fix?
    Thanks in advance
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1258
    Re: RU-513 / FS-534
    Thanks in advance
    What model copier? 4 series or 8 series? The RU-513's for the 8 series have had issues.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4788
      Re: RU-513 / FS-534
      These are all on "4" series. Forgot about "8" series using same RU-513.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Re: RU-513 / FS-534
        Haven't seen the issue yet but if I do I'll just modify the actuator to make it longer with a piece of black mylar or something similar. I've fixed numerous issues like this over the last 31 years. In particular, the duplex sensors on a C250. Almost every one needed this modification because of wear over the years.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4788
          Re: RU-513 / FS-534
          Ha-ha that's exactly what I did. I cut a piece of mylar and made the actuator a little longer and wider. If you look at actuator with RU-513 upside down it looks like it isn't even blocking photo sensor.
          • Woxner
            • Jul 2011
            • 854
            Re: RU-513 / FS-534
            had this silly problem today. turns out the floor was uneven flexing the machine. moived it a bit a presto took care of it.
            • REGSIS
              • May 2016
              • 440
              Re: RU-513 / FS-534
              Modification posted in another thread.
              Definetly install the washers if problemartic RU are within serial number range. Document 11384.pdf
              Ru-513
              • copyman
                Owner / Technician
                • Sep 2005
                • 4788
                Re: RU-513 / FS-534
                Ru-513
                Thanks anyway but this has nothing to do with issue I posted.
