C454e consumables life setting
  • Taminol
    • 171
    Hi Guys,
    Not sure if I am missing something.
    We have a C454e, it is set to DO NOT DISPLAY when life is reached for all consumables and also set to NO STOP.
    However, we received a telephone call from the client saying that the machine is displaying TRANSFER ROLLER WILL REQUIRE REPLACING SOON and THE OZONE FILTER NEEDS TO BE REPLACED.
    The machine has done 562k and the count for the Transfer roller and Ozone filter are at 18975M.
    Not sure why the machine displayed those messages when it was set not to display them.
    We've had this a couple of times on other devices recently, a Cxx4 and a Cxx8 series
    Can anyone point me in the right direction please...?
    Re: C454e consumables life setting
    Originally posted by Taminol
    Hi Guys,
    that's because the parts it is saying are near life are SERVICE PARTS
    you turned off CONSUMABLES notifications
    • Synaux
      • Mar 2012
      • 1224
      Yup, you can release the counters in service mode. There is a service level setting somewhere in service mode, but don't recall the specifics.
      • copier tech
        • 8235
        Hi Guys,
        The ozone filter & transfer roller used to come with the transfer unit so one would change as a set
        Quite often the transfer unit is replaced & the transfer roller & ozone filter rollers counters are forgotten to be reset.
        • Synthohol
          Certified Konica Expert
          • 5910
          replace the transfer kit, t/belt t/roller and filters.
          or roll the dice and reset (new release) the t/belt life and hope CQ does not go to hell.
          your choice.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            You can reset the transfer roller and toner and ozone filter counters individually. If you reset the transfer belt it will reset those counters along with it.
            • REGSIS
              • May 2016
              • 440
              Hi Guys,
              There is option not to display EOL for transfer belt, but there's no options to turn off messages for ozone filter and transfer roller.
              You can play with these options but it's highly recommended that you replace whole transfer kit when it reaches its life. On the other side you can prolong drum life and fuser life if they are ok.
              • tsbservice
                Field tech
                • 8076
                From SM (WTF is that!?)Near Life Display SettingsApplicable consumables are as follows:
                Drum Unit, Developing Unit, Fusing Unit, Ozone Filter, Transfer Roller UnitDisplay
