C654e cyan background
  • KEN
    • Feb 2011
    • 13
    [CQ] C654e cyan background
    Hi
    I have a C654e with cyan background on all colour prints config page ok
    have replaced all image units and checked HV connectors
    anyone had similar
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: C654e cyan background
    Originally posted by KEN
    Hi
    anyone had similar
    If you did indeed replace those Image units with new oem units......then unfortunately you might have an issue with the mfp board or PH unit.
      • 23009
      I'm going to guess that you've got a shorting cyan developing unit, knocking out the cyan primary charge. I believe that this machine uses color imaging units, so you'll get everything you need with: IU-711C A2X2-0KD.
      • omni
        • 30
        Hi, KEN.
        Did you solve your problem?
        I have the same issue.
