USB 3.0 & SMB V2 2.0
  • CopierNerd
    • Feb 2015
    • 207
    Konica Minolta 7 series & 8 series support SMB V2 alonh SMB V1. But my question is from where i can check or see this feature/option? I am looking for this protocol mentioned in any brochure or KM official document. OR i can check it from machine in network settings?
    Also, Konica Minolta 7 & 8 series supports USB 3.0? or Not?
  • tsbservice
    Field tech
    • 7986
    Re: USB 3.0 & SMB V2 2.0
    [Utility]
    [Administrator Settings]
    [Network Settings]
    [SMB Settings]
    [SMB Server Settings]
    [SMB Server Common Settings]
    [SMB Authentication Protocol]
    As for USB 3.0 they will work but speed is limited to 2.0, atleast for FW update.
    • CopierNerd
      • Feb 2015
      • 207
      [Utility]
      [Network Settings]
      [SMB Settings]
      you mean NTLM V1 & NTLM V2?
      • REGSIS
        • May 2016
        • 434
        SMB V1/V2 should be default setting.
        Can be checked in service mode System 2 -> software switch settings switch 219 all bits are 0.
        • Synthohol
          Certified Konica Expert
          • 5807
          hopefully this will clear things up...
          • tsbservice
            Field tech
            • 7986
            Yeah.
