AirPrint iSeries
  • Bix
    • Apr 2018
    • 1421
    AirPrint iSeries
    Hi, it seems that in the C360i the AirPrint option is not visible.
    I have seen that the printer is visible enabling Bonjour and Mopria (in reality this is for android).
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: AirPrint iSeries
    im pretty sure you need a "UK-221" for ANY type of wireless printing.
    otherwise if the wireless network and wired have the same IP scheme if the android or iphone/pad are logged into the same you can use km mobile app or see if the phone will find it on the network.
      • 30294
      • mincopier
        • Dec 2015
        • 289
        The base firmware does not support AirPrint. You must update the firmware then enable AirPrint.
        • Bix
          • Apr 2018
          • 1421
          Thanks for the videos but they were not necessary, I already know this.
          I refer to the iseries that have another interface.
          Yes, the Konica Minolta application is convenient but at the moment, when the user connects with Gmail, "Konica Minolta application is not yet authorized for this".
          • kingarthur
            • 1369
            There's a bulletin for this, you need to add a licence for each of the new models, it's on the infohub
            • Bix
              • Apr 2018
              • 1421
              I confirm
              I found the bolettin. Each model has a license to activate
              Path:
              Utilities> Administrator> Maintenance> License Settings.
              thank you
              • Max
                • Oct 2011
                • 561
                Update f/w and airprint is in the option menu. Just enable it. No need for licence.
                • rrrohan
                  • Sep 2011
                  • 1977
                  yeah i was going to say, i didnt have to do anything special on a C3350i running G00-45
