C284e scan skew
  • mrfuser
    • 1622
    C284e scan skew
    Client reported the following. Any ideas?
    The copier scans the side that is facing up crooked. The other side looks fine.
  • Synthohol
    Certified Konica Expert
    • 5848
    Re: C284e scan skew
    prolly bent the whole scanner or feeder is skewed.
    get it mechanically straight as possible then calibrate with the black box chart.
    see if it skews on the glass, if so bent scanner bed.
    • allan
      RTFM!!
      • 5462
      Re: C284e scan skew
      Yes had this idea about a perpetual functioning dildo once...
      I that case i will go out to the customer to have a look. That would give me an idea.
      Whatever
      • tsbservice
        Field tech
        • 8020
        Re: C284e scan skew
        My understanding is he talks about scanning/copying through DF and one side is skewed.
        That would leave bend scanner bed and misaligned DF out of picture I think.
        Should be something mechanical with DF in that case you need to go there to watch/test it.
        Btw allan nice comment on his confused question
        • Synthohol
          • 5848
          Re: C284e scan skew
          the CIS back side scanneris in the feeder and would scan the back side straight.
          the front side gets scanned by the scanner bed.
          it does explain why 1 side is straight.
