Tray 1 JAM 11-01/11-02 Bizhub C364
  • Bix
    • Apr 2018
    • 1421
    Hi, I have a bizhub C364 with around 100k.
    Today I received a jam call from tray 1. I said simple: since the machine was stopped 1 month, probably damp or badly positioned paper.
    Unfortunately it is not so. The most common codes are: 11-01 and 11-02. The printer has no problem printing from the second tray or from the bypass.
    I replaced the rollers but without success. I cleaned the register sensor (PS1) and the others as well. From the sensor check I find no anomalies.
    Regarding the jam: from tray 1 it can print the first sheet and then returns 11-01. Often there is no jammed sheet while sometimes it is just after the register.
    Sometimes it was able to print even 2-3 extra sheets before detecting a jam.
    Some idea? It had no problem before the holidays.
  • Bix
    • Apr 2018
    • 1421
    Re: Tray 1 JAM 11-01/11-02 Bizhub C364
    ah of course I removed the tray. No paper behind
    • copyman
      Owner / Technician
      • Sep 2005
      • 4646
      Did you change or clean the one ways making sure to scuff up shaft where one ways make contact with shaft? Did you replace the paper feed clutch?
      • Bix
        • Apr 2018
        • 1421
        Clutch is the problem
        Solved thx
        • tsbservice
          Field tech
          • 7989
          Always likes for feedbacks
          Good job Bix.
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1250
            Solved thx
            was that clutch part # Konica Minolta A02EM20200 ?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4646
              Yes that is correct part # for tray 1 PF clutch. Tray 2 also uses that clutch plus a 2nd clutch, A02EM20000.
              Just a side note, it's very rare I had to replace those clutches. Paper feed issues are usually resolved with new rollers , cleaning the one way's and scuffing up the shaft as mentioned in a prior post.
              • Toxic
                • 697
                Yes, it is rare problem but i have it few times but always on high volume machines, over 500k
