Drum counters on 8 series, partial count reset issues
  • CraigW
    • Dec 2010
    • 417
    [Misc] Drum counters on 8 series, partial count reset issues
    The start date goes to machines original start date ( not to current day) for newly installed OEM drum.
    Searched the site no luck.
  • Synthohol
    Certified Konica Expert
    • 5806
    Re: Drum counters on 8 series, partial count reset issues
    see if you change the maintenance counter if that helps?
    otherwise its still not an issue, as long as there is no end date you are ok.
    • Woxner
      • Jul 2011
      • 841
      try updating base firware and the do special. then set sw 25 to B0. i know we have a problem with these using paper cut or vcare not reporting properly
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Although it's now too late, check that the correct date and time are set (and not really the same issue as you are having but similar). I had something similar happen on a C558 a few weeks ago, not noticing the date/time were off by 2 1/2 years. When I replaced whichever consumable it was, it showed the incorrect start date that was on the machine at the time. When I corrected the date and time, it didn't change the start date, unfortunately.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
