konica c 654e help
  • anas1989
    • May 2025
    konica c 654e help
    Please Help : bypass tray paper size differs from settings please check the guid and reset using the correct papie size
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5737
    Re: konica c 654e help
    what happens if you input the correct size?
      Originally posted by anas1989
      Please Help : bypass tray paper size differs from settings please check the guide and reset using the correct paper size
      what are the settings?
      and where is the difference?
      what size are you using?
      little info to go on.
        • 22932
        If you mean that the bypass is incorrectly auto detecting the paper size ... there is a calibration for the bypass tray guides in the manual. You should do it. =^..^=
        • eccelobo
          • 113
          • richwalker
            • Mar 2013
            • 30
            Good day fellow techs. I had the same issue with a BHC 658 last week. Thought I did the calibration correctly, but found out I didn't. I don't have the 658 manual, I have the 458 and up to c654e, so I used the 654e and the c458 manuals and got the calibration done. Another tech had gone and messed with the VR and gears and threw out the settings. I thought I was going to lose my mind trying to do the adjustment, until I realized the timing was out. Sometimes you have to start from scratch to get the result you want.
            • tsbservice
              Field tech
              • 7911
              I assume your post is just FYI and not asking any real question. Is this correct?
