( 2 X ) Bizhub C754e - GREYSCALES --> CYAN !!!! ????
  • LAURENT19
    • Mar 2011
    • 16
    [CQ] ( 2 X ) Bizhub C754e - GREYSCALES --> CYAN !!!! ????
    hello
    recently, i've 2 copiers at the same time with the same Quality Default.
    When I print Demo Page with the little bird, ---->> Greyscales are Cyan.
    When I print Gradation Adjust Patern in SERVICE MODE ---->> Greyscales are Cyan too.
    Firmware : G20-M0
    1st copier 600 000 BW prints 180 000 Colour Prints
    2nd copier 250 000 BW prints 400 000 Colour Prints
    I've changed :
    UI-711C
    UI-711M
    UI-711J
    UI-711BK
    and the Transfert Belt
    But no result.
    ID Cells ??
    Laser unit ??
    Thanks for your reply
  • Toxic
    • 698
    Re: ( 2 X ) Bizhub C754e - GREYSCALES --> CYAN !!!! ????
    Somebody put cyan toner in place of black toner?
    First thing come to my mind though i never seen that on the field.
    • mo0651
      • 1054
      Have you pulled out the Black Developer unit and looked at it? make a black only copy, what do you see?
        what are you trying to print?
        does it have ANY color on the page * in formatted file * ? ( if so it may be in "composite color mode"
        • Woxner
          • Jul 2011
          • 850
          the feet does not matter. only printer. if you change all i/u's and it did it right away then it seems electronic. dont think laser is culprit.
          • allan
            RTFM!!
            • 5462
            I have . Some of the generic toner bottles are not slotted so they can work on other models so they fit anywhere..
            Will put money on that you are right.
            OP please let us know.
            Replaced the IU you say. Did it work OK for a bit?
            Whatever
            • mo0651
              • 1054
              You can change the Black drum all day, and problem won't change. The Developer unit is separate.
              • Toxic
                • 698
                You are right,CMY is imaging units but black is separate DR/DV
                • allan
                  RTFM!!
                  • 5462
                  Post an image of the gray gradations please.
                  Whatever
                  • Walterj
                    KONICA MINOLTA
                    • Jun 2017
                    • 89
                    Originally posted by LAURENT19
                    hello
                    Firmware : G20-M0
                    I've changed :
                    UI-711C
                    UI-711M
                    UI-711J
                    UI-711BK
                    But no result.
                    ID Cells ??
                    Laser unit ??
                    good day
                    Dear I recommend you check the black developing unit and the HV1 / HV2 / HV3 boards
                    Greetings
                    • LAURENT19
                      • Mar 2011
                      • 16
                      Thanks Walter,
                      I think we are on the GOOD WAY ---> the HV1 / HV2 / HV3 boards
                      I tried JUST to :
                      - Unplugged the UI-711 Cyan
                      - Reinsert the UI-711 Cyan
                      All is GOOD ( HOW LONG ..........)
                      I try this SOLUCE on 1 copier
                      Perhaps CONNECTORS of HV
                      • Walterj
                        KONICA MINOLTA
                        • Jun 2017
                        • 89
                        Thanks Walter,
                        I tried JUST to :
                        good day
                        Dear
                        If I help you, I think you should isolate the sockets and measure the continuity of the wiring that goes to the HV boards.
                        Regards
                        Luck
