Paper exit unit part#
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Does the paper exit unit part # A5C0F8950B for the Bizhub 224/284 series also fit the color C224 series models? Part numbers are different C224---# A5C0F89506
  • copyrooks
    • Oct 2013
    • 209
    Re: Paper exit unit part#
    On the KMBS Parts pricing list it doesn't have either of those part #s but it does have
    this part # A5C0F8950F Paper exit Assy
    and it does say it works for both 224e and c224e and even c454e and 454e
    • blazebusiness
      • 1250
      Thanks...I thought those units looked identical. Appreciate the info.
      • kingarthur
        • 1350
        Normally when they modify a part, they normally change the last 2 numbers on the part number, looks like they've only changed the last on this item
