FS-535 finisher dead after unpluging from a powerded on machine
  • fntsy
    • Aug 2008
    • 26
    Hi,
    The finisher was working fine attached to Bizhub 754. The client moved the machine to another place and on arrival I found the cables unplugged. After that the machine acts as if nothing is attached to it. The finisher main board has some LEDs that light up and that is all it does.
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: FS-535 finisher dead after unpluging from a powerded on machine
    i came across that scenario.
    had to replace the finisher board AND the board in the bridge unit then all was well.
    • Toxic
      • 697
      I haeard from coleague who have problem like this,fried fns board propably with static electricity.
      He got info from KM when dissconnecting connectors always unplug first small connectors with many wires and last one power connector where is ground to main body.
      When connecting finisher procedure is reverse,first connect power connector.
      • guitar9199
        • Sep 2016
        • 1100
        If the finisher was unplugged from a powered on machine, you likely have a fried Finisher control board.
        I'd bill the customer for it....that wouldn't be covered under a service contract.
        • allan
          RTFM!!
          • 5462
          Agreed that that should be billable. All maintenance agreements i know of prohibits the customer from relocating the machines by them selves.
          Whatever
            • 23002
            Just FYI: if you find that you've accidentally unplugged an accessory on a live machine... Don't immediately plug it back in. That is when the damage mostly occurs.
            Turn Off the power in the correct order, reconnect cables, THEN power back On.
            • tsbservice
              Field tech
              • 8000
              That's interesting and sounds reasonable...but most damages are done by plugging/unplugging options into live main body.
              I'm in habit to never ever disconnect or connect accessories from plugged in machine.
              I confess some day I may be unlucky but I might be wrong
              • Toxic
                • 697
                This is 100% right.
                • allan
                  RTFM!!
                  • 5462
                  On these if you yank them out and plug them back in you need to restart the machine to get it working again.
                  Don't ask me how i know that. Thought to myself what have i done. Then i did it again...
                  Did they move more than one machine?
                  Whatever
                  • fntsy
                    • Aug 2008
                    • 26
                    Thanks for your fast answers. I did find another machine to make tests. Turns out it was only the small board on the bridge unit that was fried - part # A2Y1H101
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      Lucky for the customer.
                      I had one do this on a c754e which corrupted ssd & mfp board together. I was instructed by support to replace both and carry out the special instructions required to do so. It was an expensive day for this customer.
