New C458 with washed out colors
  • AVux07
    • Oct 2007
    • 57
    This machine has 10,000 copies on it. When it was installed it looked fine, now all colors are washed out. I tried a K drum and an HV Bd but neither helped. Gradation Adjust hasn't made any difference. Has anyone seen anything like this?
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: New C458 with washed out colors
    I'm sure I must have missed something, what's wrong with the image? Looks ok except some highlights like 10 and 5%.
    • tsbservice
      Field tech
      • 8002
      Looks like all colors are faded a bit. I'm curious why you choose to change K drum?
      Did you check voltages and sensor readings in SM, anything outside normal range?
      Toner save mode on?
      • Synthohol
        • 5814
        Print another and put back in tray and print another on the back side.
        If it's a better saturation then you probably have humid paper.
        Run a couple toner add cyxcles,
        Background data Reset and stabilize, run all gradations 3 times each and recheck.
        Let us know.
        • AVux07
          • Oct 2007
          • 57
          Tsbservice was right, Toner Save was on.
          • tsbservice
            Field tech
            • 8002
            Originally posted by catherinemarms
            Any ideas?
            Yeah GFY
            • Synthohol
              • 5814
              was unaware we have a Heidelburg forum
