CD011 Error on Bizhub C368
  • Xer0615
    • Jan 2019
    • 48
    Sorry to come to you folks with such a basic question. I am a Kyocera trained technician, but my employer has quite a few Konica's in our fleet.
    One of our customers has come up with a CD011 Error, at first a trouble restart fixed the issue but it has since resurfaced.
    I have already researched the nature of the code to find out it means the "hard disk is out of spec"; which I am taking to mean that the hard drive is failing, needs replaced.
    I have found video instructions, as well as a service manual, so the physical act of changing the hard drive seems like it will be breeze.
    But I have two questions that I can't seem to get an answer to:
    A) Will any laptop-form-factor hard drive be acceptable for this particular machine? does the capacity, read/write speed matter?
    B) Will it require both a logical format (through the admin controls) as well as a physical format (via the service mode) if it is a brand new hard drive?
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: CD011 Error on Bizhub C368
    If you're installing a brand new hard drive just put it in and do a logical format if it's a used Drive plug it into a computer remove all the partitions create a new Partition do NOT format it in the PC. and then install into copier and also do a logical format hard drive size should be a minimum of 250 gb but a 320 is recommended as that's the normal size of the original.
    Western digital is recommended but I he had success with Hitachi
    • copier tech
      • 8176
      We've seen this issue multiple times now especially on the early 8 series.
      Error points to the HDD however 99% of the time machine needs the SATA firmware updating. (see link)
      https://mega.nz/#!hQUUBAoK!o0D1MSUd5...hpz-eCSyFiGEzs
      • Brett GS
        • Jun 2013
        • 154
        Had a c368 and c258 doing this,changed hdd's and after a few hours coded again.
        Both times i needed to replace the mfp board.
        • copier tech
          • 8176
          Yeah it can be any of those as this code is a bit generic however that bulletin has helped us out multiple times.
