C654e dark background only on A3
  • rrrohan
    • Sep 2011
    • 1977
    So have a C654e
    Replaced the ADF about 3 weeks ago due to so many mylar guides being worn out.
    fast forward today.
    they do A3 copy for first time since ADF got changed (they do A3 once in a blue moon).
    To be honest i never tested A3 on replacing the ADF only A4.
    So the Dark background occurs via Glass, via ADF using slit glass and via ADF using CIS. But only A3.
    I could understand if it was only when using the CIS since ADF got changed but not the CCD aswell.
    Also worth noting, i replaced the CIS black cable with the newer softer style due the C9404 error today but the problem was occurring prior and post replacement of cable. but the C9404 error is gone now.
    Any idea's? thank
  • Bix
    • Apr 2018
    • 1421
    Re: C654e dark background only on A3
    Hi, maybe the CIS cable is probably pinched or with transport could be slightly detached.
    Try to unplug and re-attach the cable. On the manual: CIS Cable (DF-701)
      • 22997
      I certainly can't explain it affecting BOTH OC (off the glass) and second side CIS. Perhaps the color table is corrupted. Aren't there quality calibrations to be done when changing the DF and/or CIS?
      • Bix
        • Apr 2018
        • 1421
        Hi, I'm looking for advice
        I have taken several A4 iSeries and they are very low in height with the DK-P04x cabinet.
        I have seen that there are spacers that regulate PF-P22 height but with the configurator they seem low to me. We would need at least 2 PF-P22 + DK-P04x.
        Can any of you tell me if one spacer is enough?
        • rrrohan
          • Sep 2011
          • 1977
          im going back today to run the procedure for only changing the CIS board
          CCD calibration to off
          Line Mag calibration to off
          FD-Mag adjustments to be run
          Main scan direction zoom adjustment to be run
          and non image area erase just in case
