Konica C1080 part number help
  • davidj7
    • 1107
    Hi
    I need to replace part #A03X656203(item No 24 in P 42,PDF page 94) in PF707. My problem is I am unable to locate the part # of the bottom part which holds the knob tight in place .
    I haven't opened this section and I was hoping to have all the parts with me before i start.
    Thanks in advance
    a machine is only as good as your tech : source:screwtape ; the scary one
    • 22999
    Re: Konica C1080 part number help
    It's threaded into the side frame #33. I've seen the threads into that frame strip out.
    It's a simple task to drill and re-tap the frame a few millimeters over and screw the thumbscrew into the new threaded hole. =^..^=
    • davidj7
      • 1107
      thanks blackcat
