rebooting
  • TSS
    • Jul 2018
    • 30
    rebooting
    Hi. I have a problem with a Konica c454e rebooting.I turn on copier,one fin comes up,some motors and fans cycle.scan light never comes on.10 or so seconds after turning on the copier,it shuts down,beeps then reboots. It constantly reboots.I resitted all connections on mfp board and took out ram memory and cleaned contacts.looking for some help.Also can i swap standard ram from another c454e?The copier up until yesterday was fine.Thank You.
  • Bix
    • Apr 2018
    • 1421
    Re: rebooting
    It could be ssd
    • korthr5
      • Feb 2016
      • 39
      Re: rebooting
      Usually is SSD
      Good luck
      • tsbservice
        Field tech
        • 8007
        Re: rebooting
        You likely have to replace SSDB, call a tech as there are some checks and steps to be done prior this.
        • Synthohol
          Certified Konica Expert
          • 5822
          Re: rebooting
          +4 on the SSD advice.
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            Re: rebooting
            Before replacing the SSD, you might try a F/W update to the latest version. If it works, no need to replace the SSD.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • 23006
              Re: rebooting
              Just to clarify, you can get somewhat similar symptoms from a bad HDD. The machine will come to "Ready", and you might get one copy before the machine re-boots. If you're quick enough to get into service mode, you'll see the HDD capacity at 0MB.
              But yes, I'll add another vote for the SSDB. They've been covered under manufacturer warranty if you're a dealer. =^..^=
