C224e draw issues
  • jonpaul
    • Jul 2014
    • 59
    C224e draw issues
    We ve got a C224e with draw 1 problems.It randomly shows A4 as 81/2 by 11 then ??? and it does not recognize paper in the tray but the light does not go on, but it does when you open the draw. We changed the tray,transport and the size sensor at the back.no joy.Thanks for any suggestions.
  • gere1
    • Oct 2018
    • 20
    Re: C224e draw issues
    your cable may have gone
    A161N10N01
    It is the reference of the drawer 1 usually broken
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      A161N10N01
      Huh. What cable? Think you have the machines mixed up. Tray 1 in the C224 is a 500 sheet tray. The C654/754 have LCC's that use a cable but they are labeled 3 & 4. The old bizhub 601 had the LCC's at top and were tray 1 & 2
      I've work on many Bizhubs and only cables I'm aware of are for LCC's, finishers & scanner/lamp assy. Never a regular paper tray.
      As for the posters original question, sounds like the guides that slide are not locking in place all the way. You have to try and get the gudies to lock deeper into size slots. And as last resort if customer only uses the tray for one size you could put small self tapping screw somewhere to hold guides from moving. Also could manually set the tray to the size instead of auto.
        • 30291
        Take it off auto and set draw size
        • tsbservice
          Field tech
          • 8020
          This cable - Key 1 :
          • copyman
            Owner / Technician
            • Sep 2005
            • 4718
            [ATTACH=CONFIG]43739[/ATTACH]
            I guess a language difference. We call that a wiring harness with connectors. Never in 45 yrs in this biz have I heard it called a cable.
            And this is what Konica Minolta calls it: A161N10N01 "Paperfeed Wiring /Rear" EA 7.87
            • Synthohol
              Certified Konica Expert
              • 5846
              check the guides when paper is in it, when the customers load the drawers and close them like they are bowling for a strike, the guides shift back and screw up the auto size function.
              the 8.5 or 11 should line up with the edge of the paper, not 3mm+ towards the rear.
              • jonpaul
                • Jul 2014
                • 59
                We changed the whole draw so it can t be the guides,we ve taken off auto but cant find how to manually set paper size and orientation.And we still have the issue of it not recognizing paper in the draw, and the orange light going on whan you open the draw.
                • Toxic
                  • 698
                  Almost 100% sure its problem in in draw paper size sensor wiring,have same case recently.
                  • DigiMan
                    • Jan 2013
                    • 262
                    +1 on the wiring,changed it 1 week ago for the exact same issue.
                    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
                    • jonpaul
                      • Jul 2014
                      • 59
                      Is that the sensor behind the draw?How do you access to that?
                      • tech51
                        • 846
                        Back covers and white side cover off. Unscrew and swing out the board box. Remove the hv board and there it is.
                        • ccfc87
                          • Feb 2014
                          • 18
                          I have exactly the same issue on a KM284e. I have twice ordered A161N10N01 and harness does not fit the sensor assy?
                          No modification notices on dbox for the harness or the sensor assy? Are KM putting the wrong harness in the bag??
