c220 display wont turn on
  • afterhours
    • Mar 2017
    • 152
    Hello, im having an issue with a C220. We replaced the power supply to no avail. The machine sounds like its turning on. The mfp fan runs, leds turn on, the lue light around the start button lights up, but the hour glass never comes on and the display stay dark. Any ideas?
    Im a Loser Baby!!!
    • 23009
    Re: c220 display wont turn on
    My suggestion is to change the page memory. When the screen becomes visible you'll most likely have additional error codes, but then you can read the screen and use the manual. =^..^=
    • afterhours
      • Mar 2017
      • 152
      I dont know what you mean my change the page memory. Please help.
      Im a Loser Baby!!!
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        You could have as issue with MFP pwb or NVRAM. Have you tried loading firmware? Sometimes screen will come up for F/W. At least that would tell you if LCD display is bad. Not sure but see if there is a reset firmware for that model.
          • 23009
          I just opened my manual > control+ F > then typed "DIMM"
          After a few clicks on "Next" it brought me right here. Amazing!:
          • mikeena
            Branch Technical Manager
            • Mar 2007
            • 220
            I'm sorry if I missed this but have you changed the display yet
            • rrrohan
              • Sep 2011
              • 1977
              ive had this when cable to touch panel cable isnt locked in place with the two screws and it comes loose.
              Also check both ends and also the silver cable that plugs in below it at the MFP
              Hopefully its simple as that
              • tsbservice
                Field tech
                • 8020
                Clean/reseat DIMMs. Try swapping DIMMs if there are two.
                If panel start to work you may have to reset/replace NVRAM though.
                • Bix
                  • Apr 2018
                  • 1421
                  That's right, make sure the cables in the side door are in the corresponding USB ports.
                  Also make sure the display cable is connected. Sometimes customers can disconnect and attach the network cable, also moving those cables.
