biz223
  • Gab
    • Aug 2015
    • 671
    biz223
    Copier had light copies and one line on image. I replaced developer, drum, blade , executed all programs and image was ok.
    After 3 weeks customer told me that the light image came back. Any idea?
  • escalante
    • Sep 2018
    • 115
    Re: biz223
    good morning. I delete the counters of the developer, drum and then execute the adjustment of the drum and developer.
    Enviado desde mi SM-J701M mediante Tapatalk
    • copyman
      Owner / Technician
      • Sep 2005
      • 4654
      Re: biz223
      If you go into user management and add toner (think that where it was with biz250, not sure with 223) does it get darker. Using genuine toner? Also I have replaced a few toner motor gears for light copies on that model. Remove the toner hopper assy and look at the toner motor under exit cover.
      • Toxic
        • 697
        Re: biz223
        OEM toner or replacement toner used?
        Does drum have damage on rear side?
        • Woxner
          • Jul 2011
          • 844
          Re: biz223
          if the toner motor was bad it woulkd give a motor code and noise. ck door ground copper contacts ans repl transfer roller if its old.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4654
            Re: biz223
            I've had no noise and no codes with light copies on this model. I thought the same thing, why no code. Anyway it's easy to check
